need taillight wiring diagram for 91 YJ - JeepForum.com
post #1 of 15 Old 01-28-2009, 11:50 AM Thread Starter
willyb8
willyb8's Avatar
my heeps got
BLK
BLUE/RED
WH/BLK
BROWN/GREEN
hayes manual only show a 3 wire config, with totally different colors.
the PO installed a trailer harness half a**. i just started to install some flush LED tails and need to know which wires go to what? searched around but got some different colors for 95's. any help would be great
Thanks
91 YJ 4.0 HO,
3.5" BDS, 5/8 MORE Booms, 1" BL, MML
AA SYE & CV,
35" Maxxis Bighorn
Smittybilt XRC8 Winch,
8.8 W/Elocker, D30 W/Aussie
Genright tube fenders
willyb8 is offline
post #2 of 15 Old 01-28-2009, 11:55 AM
rrisher
1987 YJ Wrangler
THIS might help you...
rrisher is offline
post #3 of 15 Old 01-28-2009, 11:58 AM
kloppk
Originally Posted by willyb8 View Post
my heeps got
BLK
BLUE/RED
WH/BLK
BROWN/GREEN
Thanks
BLK - Ground
BLUE/RED - Running Lights
WH/BLK - Left Directional/Brake
BROWN/GREEN - Backup Lights
BROWN/RED - Right Directional/Brake
kloppk is offline
post #4 of 15 Old 01-28-2009, 12:17 PM
driveajeep812
hey rrisher thanks for that pdf! I was looking for something just like that but had never found one. Its pretty sweeet man thanks!
-Keith
driveajeep812 is offline
post #5 of 15 Old 01-28-2009, 12:32 PM Thread Starter
willyb8
willyb8's Avatar
i found that one already but it shows different colors and top brake lights so i figured it was for the TJs
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #6 of 15 Old 01-28-2009, 07:57 PM
rrisher
1987 YJ Wrangler
It's the YJ one... Just remember on these heeps the colors fade and the stripes somehow disappear after time.
rrisher is offline
post #7 of 15 Old 01-28-2009, 08:24 PM Thread Starter
willyb8
willyb8's Avatar
Originally Posted by kloppk View Post
BLK - Ground
this one worked, thanks
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #8 of 15 Old 01-28-2009, 08:25 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I just did mine a couple of weeks ago, I love them!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 15 Old 01-29-2009, 04:38 AM
Stauffeneker
2014 JK Wrangler
Will that wiring link work for 89 YJs too? I'm in bad need of one.
Stauffeneker is offline
post #10 of 15 Old 05-08-2011, 04:31 PM
ghiradelli777
do you have to ground the LED lights to the body or is there a ground on both sides for it?
1992 YJ Sport White 4.3 swap in progress
Eagle Scout Jeep Owner
ghiradelli777 is offline
post #11 of 15 Old 01-05-2012, 02:27 PM
AZdEvilYJ
I would like to know this also ^^^ I am doing the incandescent flush mounts and having problems with wiring...
AZdEvilYJ is offline
post #12 of 15 Old 01-05-2012, 06:00 PM
Mark05059
the lamps your installing will have a pigtail on them (or available separately) which will have a ground wire. That ground wire needs to be grounded to something. Could be frame/tub/battery. just be sure that the metal is clean and not rusty at all.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #13 of 15 Old 01-07-2012, 04:30 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
See my 2nd writeup on LED light installation. It covers all aspects of the wiring, including the ground.
http://www.jeepforum.com/forum/f12/h...lights-976895/
Max
Mean Max is offline
post #14 of 15 Old 01-08-2012, 08:08 AM
JWELK
The color code varies from year to year, I think it even changes from model to model. It is as if they use whatever they have lying around. My recommendation, is to use a test light and verify each wire. The only common seems to be black is ground. When using a test light, use an extension lead and run the ground side to the battery, a jumper cable while overkill, will work, This will eliminate the faulty ground problems. I have looked in several manuals and the color codes sometimes vary from manual to manual. Those that are the same are probably plagiarized.
Regards,
Jim W
JWELK is offline
post #15 of 15 Old 01-08-2012, 05:46 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Regards,
Jim W
Jim, there is no ground wire for the YJ tail lights. The ground is accomplished by the three mounting screws that attach the tail light housings to the body. This is why a separate ground wire must be installed for modified lights.
Also, the typical aftermarket lighting wiring harnesses utilize 3 wires for STT (Stop, Tail, Turn) applications. Most all of these will be black, red, and white in color. Black will be for the low output lighting of the parking circuit. Red will be for the high output lighting of the brake & turn circuits. And finally, the white will be the ground for both circuits, which oddly enough flies directly into the face of the "black is ground" school of thought.
Hope this helps!
Max
Mean Max is offline
302 to YJ wiring Diagram GEAH YJ Wrangler Technical Forum 4 04-24-2014 09:11 PM
Taillight wiring question mateas TJ Wrangler Technical Forum 18 03-06-2009 07:15 PM
need wiring diagram majkowskid TJ Wrangler Technical Forum 4 07-18-2008 07:04 AM
Taillight wiring BigCanoe TJ Wrangler Technical Forum 6 06-12-2005 10:49 AM
Taillight wiring BigCanoe YJ Wrangler Technical Forum 1 06-11-2005 07:44 AM
