need suggestions! - JeepForum.com
post #1 of 2 Old 06-27-2002, 12:15 PM Thread Starter
4wheelinfool
4wheelinfool's Avatar
1980 CJ5
need suggestions!
I just ordered a 4" suspension lift from procomp. The kit included front and rear springs,u-bolts,4shocks, and a drop pitman arm, and a transfer case drop kit. the question is what if any other hardware do need to make this a long lasting lift kit. Do i need brake line extensions, swaybar extensions, trac bar extensions or anything like that?
92 yj stock for now but not for long
R.I.P one Baddass 92' yj that had 5.5in in the front and 6in in the RR with 33x 12.5's Baja Claws with homemade everything and a whole lot of sweat, blood, and tears that went into her......... But i did just get an 80' cj5 that is getting 4.5in RE, 1in Daystar, bushwackers, winch, and ox lockers, gears, and some meaty 35in BFgoodridge Krawlers.. oh yeah baby
4wheelinfool is offline
post #2 of 2 Old 06-27-2002, 01:43 PM
StumpJumper
longer brake lines
quick disconects for the front swaybars(if you keep them on)
new rear main seal for when you see how much yours leaks after you lean the engine back
87 w/ 258 5spd. Weber 32/36. TFI upgrade. 4" Skyjacker lift w/quick disco's. 1" DayStar bodylift. Rancho 9000's. 33x12.5 ProComp muds. Oil stained driveway!!
StumpJumper is offline
91 YJ suggestions shane_huskey YJ Wrangler Technical Forum 1 09-08-2008 01:16 PM
In need of some suggestions ! sgtcherokee YJ Wrangler Technical Forum 2 03-03-2007 08:18 AM
suggestions? figbush1 TJ Wrangler Technical Forum 3 03-02-2007 12:07 PM
BL Suggestions? tmwoodall TJ Wrangler Technical Forum 2 02-25-2007 04:08 PM
any suggestions? sasquatch3805 YJ Wrangler Technical Forum 10 05-06-2006 09:43 AM
