Need some wiring help! - JeepForum.com
post #1 of 8 Old 03-04-2013, 06:46 PM Thread Starter
ghetdjc320
I have an 88 YJ that had a 4.2 and I am swaping in a stroker with fuel injection. I have the harness for a 93 XJ for the engine compartment and I also have a 94 YJ dash harness. I decided to replace both because they are fairly compatible with each other and also because I am putting in a custom CJ dash so I might as well re-wire with the dash out. My problem is finding the connections to tie in with my existing body harness. The connectors are completely different. I assumed they would be different because of the rear electric fuel pump ect. I have looked at alldata and cannot find any diagrams for the dash to body connections. I can custom splice them together if I can just know what goes where. Please help!
-DJC
ghetdjc320 is offline
post #2 of 8 Old 03-05-2013, 07:34 AM Thread Starter
ghetdjc320
Bump
Anyone??
-DJC
post #3 of 8 Old 03-05-2013, 08:42 AM
Que89YJ
Que89YJ is offline
post #4 of 8 Old 03-06-2013, 08:13 AM Thread Starter
ghetdjc320
Originally Posted by Que89YJ View Post
The problem is the body connector pinout is not in an FSM or at least not that I can find.
-DJC
post #5 of 8 Old 03-06-2013, 08:24 AM
wncYJ
wncYJ is offline
post #6 of 8 Old 03-06-2013, 09:30 AM
Que89YJ
Body bulkhead connector.
Que89YJ is offline
post #7 of 8 Old 03-07-2013, 09:39 AM Thread Starter
ghetdjc320
What I need is the pinout for the connectors that attach to the dash harness and run under the drivers side door sill. I need the dash side of that connector (not the bulkhead connector) for a 94 yj
-DJC
post #8 of 8 Old 03-07-2013, 09:49 AM
Que89YJ
The dash side is the same. The wires connect in the bulkhead. Here is a link toa thread with the FSM from 87-90.
http://www.jeepforum.com/forum/f12/j...39/index2.html
Que89YJ is offline
