Need some opinions - Page 2 - JeepForum.com
post #16 of 26 Old 07-15-2013, 12:05 AM Thread Starter
YJ_Squared
Originally Posted by jason280
Are the rear bolts simply too rusted to remove, and you are having to cut them out? I know on my '94, I had to unbolt and move the gas tank side to side to remove the rear frame-shackle bolts. I'm not sure if this is the factory installed them all this way, but there was no way to pull the upper bolts out with the gas tank bolted up....the bolts are simplt too long and there was not enough room to remove them with the gas tank in place.
I didn't have to completely drop the tank, but I did have to wedge it around a bit to clear the bolts. If Jeep had simply installed them with the nuts on the inside of the frame (closest to the tank), then it would not have been an issue.
Yeah that's the problem I had. I was not worried about keeping the stock shackles so I just hacked em up to get everything out. Now that I have room to work the upper shackle bolts should not be an issue. One thing is for sure, the new ones will be going in the opposite direction!
1995 YJ, just getting started.
2012 F150 FX4 Tow Rig
2003 Kawasaki KFX 400
YJ_Squared is offline
post #17 of 26 Old 07-15-2013, 05:09 AM
amerdt4
Yeah , those main eye bolts suck , I am on my second Yj and in both those bolts were seized . The fist time I spent a good amount of time tryng to pb blast them and beat them out before I took a sawzall to to them . Second time around I tried the impact gun with the same result so I just took an angle grinder to them with a cut-off wheel , took 30 sec .
amerdt4 is offline
post #18 of 26 Old 07-16-2013, 09:46 PM Thread Starter
YJ_Squared
Yeah these will be getting the sawz all treatment as soon as I get back to work on it. I'm lucky to get a few hours a week on this thing.
post #19 of 26 Old 08-24-2013, 05:34 PM Thread Starter
YJ_Squared
Finally got the front axle under this thing. Still need to hook up my hydro steering but it's sitting on at least two tires now. I still need to cut the perches off the rear 9" and weld them where I need them. Hopefully next Saturday it will at least be sitting on all fours. I was strapped for time but I will be taking more detailed pictures next week.
post #20 of 26 Old 08-24-2013, 05:37 PM Thread Starter
YJ_Squared
I need to have this thing done by the first weekend in October and it is looking like I will be done by then. I still need to install my SYE, hydro steering and brake lines. I also plan to remove the front fenders until I can get some tube fenders built.
post #21 of 26 Old 08-24-2013, 06:05 PM
AmmitOsiris
The sye is very simple just make sure you have rtv and a good set of snap ring pliers, and if need be, get a new chain and whatever you need to fix with the chain
Sent from Peggy's office
AmmitOsiris is offline
post #22 of 26 Old 08-24-2013, 09:50 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I need a new set of snap ring pliers.
Luck Favours The Prepared
Anticanman is offline
post #23 of 26 Old 08-24-2013, 09:55 PM
AmmitOsiris
I know you do..
post #24 of 26 Old 08-24-2013, 10:01 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I know you do..
My birthday is next month and I have a transfer case that needs to be rebuilt in my shop.
post #25 of 26 Old 08-24-2013, 10:09 PM
AmmitOsiris
No your birthday isn't next month.. Never lol, I got this, I'll swing by for your bday.. Or I'll try.. Depends on school
post #26 of 26 Old 08-24-2013, 11:34 PM Thread Starter
YJ_Squared
Oh yeah, no problem with the sye. This will be the third I've done. No problem so long as all the parts aren't wore out like the last one I did.
