-   -   Need some injector help (http://www.jeepforum.com/forum/f12/need-some-injector-help-1754714/)
ionakana 11-03-2013 08:00 PM
1 Attachment(s)
I just got these injectors from a friend, his jeep is toast. Somehow from the time we removed them to the time I installed them in my Jeep one went bad. My stock injectors were bad so he Jeep is down now. These are an upgraded injector, my friend thinks their ford but can't remember, it's been a while since he bought them.
I know it's a Bosch and it's 4 hole. The #'s on the side are F6VE-A5A and 0280-155-710. I believe it's a Ford 19lb injector.
What is it from? I need to run down to the pull-a-part and get one.
Thanks.
PA_YJ19 11-03-2013 08:42 PM
Ford mustang (94-98), crown Vic(94-04), grand marquise, explorer v8, thunderbird(94-97), nething ford with a 4.6l v8 engine has the 19lb injectors. Also a few Saabs and volvos of the same time period came with them and neons with 2.0l engine.
ionakana 11-03-2013 09:12 PM
Thanks. Should I change the pressure regulator?
PA_YJ19 11-04-2013 10:47 AM
Only if u upgraded ur engine and feel the need to, if it is stock and controlled by the computer, I wouldn't bother. Mines a strocker n I didn't upgrade it, really no need too. The main benefit is the way they spray the fuel as a mist instead if a steady stream, allowing the fuel to b used more efficiently.
superj 11-04-2013 11:23 AM
any small ford v8 came with those. i got some a few years ago from a ford van.
don;t forget the mercury vehicles are fords too, as are lincolns so all use the same injectors
ionakana 11-04-2013 01:31 PM
Thanks guys!
The time now is 10:48 PM.
