Need some info - JeepForum.com
post #1 of 7 Old 10-16-2001, 07:41 PM Thread Starter
yjjeepin
Need some info
ok im going with 33s with 4.11 gears or 35s with 4.56 gears, with a re soa lift kit with a 1" body lift and re's full length add-a-leafs 2.5" with that lift what else should i get besides a sye, and is there a good sye for around $300 to $400, this will be off road only on the weekends, any ideas thanks
yjjeepin is offline
post #2 of 7 Old 10-16-2001, 08:50 PM
RodeoRob
RodeoRob's Avatar
You'll be doing SOA, 1" BL, and 2.5" add-a-leafs and you'll only be running 33's??? I'd say with the kind of lift you are talking about, you could be comfortably running 35s.
check www.jbcoversions.com and Tom Woods Driveshaft for SYE kits. You should be able to do one for $400.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 7 Old 10-17-2001, 07:54 PM
bob91yj
If you are on stock axles, I'd stick with the 33's, or carry a good supply of spare axle shafts.
I'm SOA on sagged 2-2.5" Skyjackers, and can rub Pro-Comp MT 33's on ocassion. As far as the gears, I've got 4.56's, and I'm turning 2700-3200 rpm on the highway, 4.0L, 5-speed.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #4 of 7 Old 10-17-2001, 09:06 PM
shea324@aol.com
Take the body lift out the equation, if you still need clearance, I have seen fender flare trimming that adds an inch of clearence without looking too butchered
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #5 of 7 Old 10-17-2001, 10:19 PM Thread Starter
yjjeepin
thats why im staying with the 33s cause of the stock axles, what would be a good upgrade for the axles? that is easy to put in and is strong enough for 35s, where can i find a dana rear 44 that i could put in the rear trying to save as much money as possible
yjjeepin is offline
post #6 of 7 Old 10-19-2001, 12:23 PM
bigblueyj
here a friend has 4 popper with 4.56 gear 33's and soa on stock springs the thing will go any where
bigblueyj is offline
post #7 of 7 Old 10-19-2001, 12:24 PM
bigblueyj
opps heres the link http://rayray.rockcrawler.com
need lift info & regearing info stuart2410 JK Wrangler Technical Forum 3 01-18-2009 09:28 AM
need info on cps on 89 i6 lee95yj YJ Wrangler Technical Forum 1 09-01-2008 06:01 PM
Too much info...help rxl TJ Wrangler Technical Forum 5 02-28-2008 01:05 PM
Factory Warranty info? Top info? BlueRidgeRunner TJ Wrangler Technical Forum 5 06-27-2004 03:52 PM
need some info about this... wakeboarder 21 TJ Wrangler Technical Forum 1 10-15-2003 05:01 PM
