need some help as to y this seal keeps going... - JeepForum.com
post #1 of 8 Old 05-03-2011, 09:46 PM Thread Starter
EvolvingWorld
i had recently replaced my transfercase output shaft seal and it went again in the same day about an hour after i ran my truck.. what could b causing this problem...????should i lightly sand down my rear shaft and coat it with a gloss paint...????
EvolvingWorld is offline
post #2 of 8 Old 05-03-2011, 10:25 PM
NonRubicon
No. Sanding won't help, but you are correct in suspecting the slip yoke shaft as the culprit. If the seal is correctly seated and undamaged then the reason you still have a leak is because the slip yoke shaft is worn. The tolerances are very close for the slip yoke and the bearing. Paint won't fix it.
Replace the seal and bearing in the tailcone housing, and the slip yoke - then your leak will go away. While you are at it, might as well replace both rear driveshaft u-joints for good measure. If the slip yoke is worn, it's a good bet the u-joints are too.
NonRubicon is offline
post #3 of 8 Old 05-03-2011, 10:31 PM Thread Starter
EvolvingWorld
thank you, appreciate the post i will check everything out.. and change it out.
post #4 of 8 Old 05-04-2011, 07:03 AM Thread Starter
EvolvingWorld
When I get the new slip yoke can I coat it with something so it doesn't get that build up on it.....
post #5 of 8 Old 05-04-2011, 08:06 AM
Lemoore-on
I think there is a bushing in the housing that can be replaced also. I dont have time to look it up right now.
Lemoore-on is offline
post #6 of 8 Old 05-04-2011, 08:21 AM
Flajeeper1
1987 YJ Wrangler
X2. If your seal went in the same day definitely replace the bushing in the tailshaft housing. And absolutely check the U-joints. If you're in question have a local driveshaft shop look at them. Easy to replace yourself.
Flajeeper1 is offline
post #7 of 8 Old 05-04-2011, 08:42 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The bushing in the tailshaft housing is a bronze/brass/copper type bushing. The yoke may be worn, but most likely the softer metal bushing has taken the most beating.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 8 Old 05-04-2011, 06:00 PM
NonRubicon
I had assumed the same thing at first when I developed a leak. Replaced both the seal and bushing to no avail - still leaked. Had to put in a new slip yoke to finally stop the leak. I recall a post or sticky here on JF that recommended replacing the slip yoke when you replace the bushing/seal because of the possibility of the slip yoke being worn. I decided to skip that recommendation and found out that my slip yoke was the problem.
Of course, no reason to replace the slip yoke if the problem lies in the bushing. One step at a time.
Rear main seal, and transmission seal leaking tra4689 TJ Wrangler Technical Forum 11 05-03-2010 10:47 AM
Seal driver for front axle seal, disconnect side sequel YJ Wrangler Technical Forum 24 01-24-2010 06:05 PM
Front diff seal leak out the back. how do i fix the seal?? Mitchin TJ Wrangler Technical Forum 10 01-23-2010 09:14 AM
D44 rear pinion seal vs. NP231 transfer case seal thejafe TJ Wrangler Technical Forum 14 06-14-2009 01:24 PM
Axle seal , wheel seal whats it called??? Datbastad69 TJ Wrangler Technical Forum 16 05-23-2009 07:30 AM
