Quantcast need some help w/ shock mount - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > need some help w/ shock mount
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 01-29-2006, 09:22 PM   #1
toates89
1989 XJ Cherokee
i just removed my front brakeline off my 89 6cyl and what a pain every bolt broke(rust sucks). i will soon have to do the back lines but i was looking at my left upper rear shock mount where it meets the frame and it is shot(cant be welded due to it is crumbling) so i was wondering where can i find this piece of metal and how much is it?
also i was showing some one my jeep today but earlier today i took out the air filter and its compartment was filled with crap and the big black hose that is connected to the filter, i started it up(didnt drive it) and i forgot that i took them off, is that gunna do damage?
toates89 is offline   Reply With Quote
Old 01-29-2006, 10:05 PM   #2
toates89
1989 XJ Cherokee
i really need this help. does anyone know what to do about the shock mount
Old 01-29-2006, 11:06 PM   #3
tobias94yj
Hillbilly Member
tobias94yj's Avatar
Is the frame rusted real bad where the shock mount is? Because you may need to grind down on the frame some and weld in a patch and then weld the shock mount to that. I would start doing some inspecting on the frame while you are under it and see how bad it is. If your frame is starting to rot real bad it may be safe to cut your losses.
To view the NEW Jeep Encyclopedia click here!!!
tobias94yj is offline   Reply With Quote
Old 01-30-2006, 06:24 AM   #4
toates89
1989 XJ Cherokee
no the frame is not rusted its just the shock mount crumbled and now i dont know where to get one
Old 01-30-2006, 06:55 AM   #5
vadslram
Your probably better off just getting some stock and making your own. It's either that or go to a junk yard and cutting one off another wrecked frame.
vadslram is offline   Reply With Quote
Old 01-30-2006, 07:50 AM   #6
Brown Dog
Vendor
Brown Dog's Avatar
shock mount
That is going to be a tough one. I suppose a dealer might be able to get you one. Getting one at a junkyard is an option if you find a yard that will cut one out without butchering it. If it happened to me, I would make a new one. Where are you???
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Old 01-30-2006, 07:51 AM   #7
Brown Dog
Vendor
Brown Dog's Avatar
no damage will be done due to the disconnected hose
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Old 01-30-2006, 02:05 PM   #8
toates89
1989 XJ Cherokee
i am on long island ny, how much would it cost (estimated)
Old 01-30-2006, 02:34 PM   #9
Brown Dog
Vendor
Brown Dog's Avatar
I am going to look at the mount, and will let you know ASAP what I can do.
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Old 01-30-2006, 02:50 PM   #10
Brown Dog
Vendor
Brown Dog's Avatar
As you have seen, the mount you are talking about fastens to two brackets on the frame. Is it the frame brackets, or the part the shock bolts to that is shot? I can solve either problem, but I need to know how deep I am going.
If it is the brackets on the frame, are you going to have anything to weld to??
If you can take a digital picture, it would help me.
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Old 01-30-2006, 03:31 PM   #11
toates89
1989 XJ Cherokee
it is the upper mount that is welded to the frame visible through the rear wheel well it is the mount that is crumbling at the frame the frame isnt bad just the mount
Old 01-30-2006, 03:34 PM   #12
toates89
1989 XJ Cherokee
i can get a digital pic tonight around 1030
Old 01-30-2006, 05:21 PM   #13
Brown Dog
Vendor
Brown Dog's Avatar
I'll get to work on a mount. I will design it as a one piece mount rather than the two piece as the stock mount is. You will just have to position it on the frame and weld it in place. $35 plus postage ok??
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Old 01-30-2006, 06:49 PM   #14
tobias94yj
Hillbilly Member
tobias94yj's Avatar
You are the man , I am real impressed and when I need some of your products I will definately get it from you and will recommend you.
Glock Forum
