Need some help with a starting problem - Page 7 - JeepForum.com
post #91 of 192 Old 12-05-2011, 02:49 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by The Rat View Post
Wouldn't unplugging the TPS cause it to not start anyway?
It should not fire up. Unplug the TPS while it is running also and see what it does....we're fishing for a point to work with here.....
Here is where we are; It starts poorly most of the time and also idles low then dies whenever it feels like it.
You have done a tune up and replaced several key parts and nothing has changed. Since the CEL goes on during the start cycle and goes off once started indicates that the PCM may not be the problem. Either you have a bad intermittent sensor signal or a bad wire interrupting inputs to the PCM would be a very broad and generalized guess.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #92 of 192 Old 12-05-2011, 03:21 PM Thread Starter
The Rat
Gah. Was just out there messing around and I could get it to start using the gas pedal but it wouldn't maintain or idle and just died out. Nothing really changed from this afternoon other than the air is a little more moist. Same temp.
Edit: Also, some kid got wise with me and yelled to me "it's not gonna start, buddy." I thought I had showed him once I got it to fire up a couple times. I guess technically he was wrong because it started, several times. I still feel like I lost.
OH WAIT. WHAT?
The Rat is offline
post #93 of 192 Old 12-05-2011, 03:55 PM
youngjeepr
Not sure how that would cause it to stall out so quickly, though.
x2 for a leaky injector... it could cause the engine to stall out so quickly by flooding it... when they leak they will drip fuel after you let the throttle off flooding it... then after it builds pressure it wont drip as much and alow it to run
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #94 of 192 Old 12-06-2011, 12:13 AM Thread Starter
The Rat
Any way to test that?
OH WAIT. WHAT?
The Rat is offline
post #95 of 192 Old 12-06-2011, 12:19 AM
94chb
i told you but you ignored my post. i said a few pages back it seems to be a leaking fuel injector and to test it you need to get a fuel gauge and hook it up, turn key on to prime it and get a reading then let it sit and see if the pressure drops. if the fuel pressure drops at all then you have a leak.
94chb is offline
post #96 of 192 Old 12-06-2011, 12:25 AM Thread Starter
The Rat
Oh yeah, I did that...posted a short video of it. Pressure didn't drop quickly. Left it for about 20 minutes or so and it held right around 28psi. Thought that test was for the regulator.
OH WAIT. WHAT?
The Rat is offline
post #97 of 192 Old 12-06-2011, 12:26 AM
youngjeepr
Is your jeep TBI or MPFI
post #98 of 192 Old 12-06-2011, 12:27 AM Thread Starter
The Rat
Multi Port
OH WAIT. WHAT?
The Rat is offline
post #99 of 192 Old 12-06-2011, 12:33 AM
94chb
test it again and let it sit for 30 mins then come back and check for pressure drop. also let it run and see if pressure drops while its running to see if its a fuel fuel the reason it dies.
94chb is offline
post #100 of 192 Old 12-06-2011, 12:34 AM
youngjeepr
Have you replaced your CTS or O2 sensor?
post #101 of 192 Old 12-06-2011, 12:42 AM Thread Starter
The Rat
Have replaced nothing. Picked up a crank sensor from AZ against my better judgement and the sensor fit alright but the connector was crap. Didn't make the problem worse or better though so I cleaned off the stock one and returned the crummy one to AZ. I'd have kept it if their connector actually fit all the way on.
OH WAIT. WHAT?
The Rat is offline
post #102 of 192 Old 12-06-2011, 12:45 AM
94chb
lol i bought one a year ago from AZ and the wires were only 4in long and wouldnt reach to the harness to plug in.
94chb is offline
post #103 of 192 Old 12-06-2011, 12:47 AM
youngjeepr
Try unplugging your CTS and see if your problem is still there.... Do you have any exhaust leaks around the O2 or before it?
post #104 of 192 Old 12-06-2011, 12:55 AM Thread Starter
The Rat
That's what I expected to happen when I saw the short wires, then it surprised me when it actually reached but pressing it into the connector ended up being impossible.
Assuming you are referring to the coolant temp sensor? I'm pretty sure I ruled it out when I still couldn't start the Jeep while hot. It would start right back up after about a minute when warm but then when I let it sit about 5, it would go back to cranking forever.
No leaks that I can hear, but I'll check that out tomorrow.
I really want to figure this out before it gets cold out, been working on one piece at a time in the school parking lot. I returned the fuel pressure tester the other day, so that sucks.
OH WAIT. WHAT?
The Rat is offline
post #105 of 192 Old 12-06-2011, 01:03 AM
youngjeepr
Yes I am referring to the coolant temp sensor... And if it starts when it's warm that would mean your O2 sensor is good and hard cold starts might be the coolant temp.... The coolant temp regulates how much fuel is given until the engine is at or close to operating temp then the O2 sensor takes over... So if your CTS is bad it could be telling the computer it is really cold so it gives more fuel than needed causing it to flood and not starting until enough is burnt up
no spark
Starting problem cmandes13 TJ Wrangler Technical Forum 6 12-09-2010 05:52 PM
YJ 92 4.0 Starting Problem freebird YJ Wrangler Technical Forum 0 11-08-2010 12:53 AM
Starting problem, '95 4.0 in an 83 CJ7 FOTOPHREAK YJ Wrangler Technical Forum 0 04-25-2007 06:55 PM
Starting problem... 88 YJ 4.2L Quick636 YJ Wrangler Technical Forum 2 11-07-2005 12:47 AM
Help with starting problem! Snowman01TJ TJ Wrangler Technical Forum 4 11-24-2004 07:30 PM
