Need some help with a starting problem - Page 3 - JeepForum.com
post #31 of 192 Old 11-29-2011, 05:47 PM Thread Starter
The Rat
IAC was disgusting. In fact, the whole TB was disgusting and the IAC was tough enough to get to that I just pulled the whole TB and cleaned it.
Gonna put it back in tomorrow and see what happens. Fingers crossed that that fixes it.
OH WAIT. WHAT?
The Rat is offline
post #32 of 192 Old 11-29-2011, 07:13 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Looks like it was lubricated with some roofing tar and then it was dipped in carbon black!!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #33 of 192 Old 11-29-2011, 08:11 PM Thread Starter
The Rat
Also looks like I put the IAC in backwards.
OH WAIT. WHAT?
The Rat is offline
post #34 of 192 Old 11-30-2011, 12:51 AM
SDGBASSE
If it doesn't work you could take a look at the coolant temp sensor. When you have a difference between hot and cold engine it's usually the culprit. And it's real cheap.
Originally Posted by ZeroGravity View Post
I didn't click the link because it says "power probe" in the url.
SDGBASSE is offline
post #35 of 192 Old 11-30-2011, 09:10 AM Thread Starter
The Rat
Put the TB back on, tried to start it...same as before.
Forgot to dump the memory. Unplugged the battery, wouldn't start. Cranked it a bit more and then eventually it just fired up on its own, no pedal. Took it for a quick drive and now I'm sitting in it, debating whether to let it run forever or to turn it off and hope it starts right up later.
Any other suggestions to think about while I sit in class for 2 more hours if this doesn't start right back up?
OH WAIT. WHAT?
The Rat is offline
post #36 of 192 Old 11-30-2011, 09:11 AM Thread Starter
The Rat
Also it's funny that the DRLs are triggered by vehicle motion and aren't just on by default when the vehicle is on. They work once I move.
OH WAIT. WHAT?
The Rat is offline
post #37 of 192 Old 11-30-2011, 09:12 AM Thread Starter
The Rat
Also now that it's warmed up, it will start in one crank. Runs great, intake is way loud though now since its so clean.
OH WAIT. WHAT?
The Rat is offline
post #38 of 192 Old 11-30-2011, 09:25 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
The drl takes its cue to turn on the lights (at 50% power I beleive) from movement detected by the Vehicle Speed Sensor. No movement no lights! Don't be a girly man.....shut the engine off!
post #39 of 192 Old 11-30-2011, 09:43 AM Thread Starter
The Rat
Already won't start back up. Damn. Suggestions for what to look at next?
OH WAIT. WHAT?
The Rat is offline
post #40 of 192 Old 11-30-2011, 10:05 AM
oldtime_ironman
Check for codes:
Also check for spark and fuel pressure.
oldtime_ironman is offline
post #41 of 192 Old 11-30-2011, 10:38 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
I think SDGBASSE hit a home run here. The temp sensor helps control idle, air/fuel ratio and timing. If all other items are functioning ESPECIALLY because your engine runs when warm and gives you grief when cold...the resistance of the temp sensor is wrong so the engine is setting itself up to run as if it was hot when it is cold.
That would be like trying to start a cold engine that is carb'ed and no choke and the wrong timing.
I'll be honest it did not even pop into my mind. That proves many minds are better than one....especially mine!
post #42 of 192 Old 11-30-2011, 01:04 PM Thread Starter
The Rat
May have just ruled out the coolant temp sensor:
Changed plugs/wires/cap/rotor and cranked it for a bit and got it started and ran it up to temp.
Shut it off, waited a minute, cranked and started on one turn.
Shut it off, waited 5 minutes, cranked and cranked and cranked and no start.
Doesn't sound like it's getting any spark, but it was hot still when I tried to start it again. I believe that should rule out the coolant temp sensor.
Going back to thinking that maybe it is the crank position sensor, but I can't really justify why, nor do I know how to test it properly. Still so odd that it is something that came on so suddenly, didn't even produce a warning of any sort.
OH WAIT. WHAT?
The Rat is offline
post #43 of 192 Old 11-30-2011, 01:14 PM
SDGBASSE
Check the resistance in the CRANK (not cam) position sensor at the connector it should read between 125-275 ohms.
EDIT: not applicable on 92-95's.
SDGBASSE is offline
post #44 of 192 Old 11-30-2011, 01:18 PM Thread Starter
The Rat
Which pin to which pin? Went out there and couldn't read a resistance on the connector coming from the sensor.
OH WAIT. WHAT?
The Rat is offline
post #45 of 192 Old 11-30-2011, 01:24 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Something that is sending a signal or power is not working all the time. I would be very surprised if this is not an electrical issue.
Does the CEL come on every time the ignition is turned to the ON position for a few seconds. Do you see the CEL go on whenever you turned the key to the ON position but it did not start? VERY IMPORTANT I would think.
You think it is not getting power to the plugs when it does not turn over. You have to prove that.
When it is cranking but not turning see if the distributer is getting power from the coil. If it is how about the individaul plugs?
In the Power Distribution Center under the hood. What conditon are the relay/fuse sockets? Are they clean or do they show signs of corrosion?
Until you narrow down what system is failing at what point you could throw parts at this jeep until you are broke...
no spark
Starting problem cmandes13 TJ Wrangler Technical Forum 6 12-09-2010 06:52 PM
YJ 92 4.0 Starting Problem freebird YJ Wrangler Technical Forum 0 11-08-2010 01:53 AM
Starting problem, '95 4.0 in an 83 CJ7 FOTOPHREAK YJ Wrangler Technical Forum 0 04-25-2007 07:55 PM
Starting problem... 88 YJ 4.2L Quick636 YJ Wrangler Technical Forum 2 11-07-2005 01:47 AM
Help with starting problem! Snowman01TJ TJ Wrangler Technical Forum 4 11-24-2004 08:30 PM
