Need some help with a starting problem - JeepForum.com
post #1 of 192 Old 11-27-2011, 02:43 PM Thread Starter
The Rat
So I can't seem to figure this out. Last Wednesday, I drove to Dunkin Donuts at like 7am, everything was all well and good. Parked it til about 1pm when I was gonna leave for the weekend, cranked forever with no start. Here's where things get weird:
I know that sometimes the CEL doesn't come on and it won't start until I wait for it to come on. That could be caps in the ICM deciding to go bad...but regardless it always starts when the CEL comes on. This time it did not. Just cranked and cranked and cranked, until I eventually got it started and it just blew the richest exhaust. Must've flooded it. Either way, I decided to let it run for a minute and then take it for a ride. Stalled out down the road, like complete loss of power. Started it up again, stalled out again. Repeated until I made it mostly into a parking spot and then decided it had enough. Wouldn't start at all.
Flash forward to today, let it sit all weekend at school while I was not enjoying Thanksgiving due to this problem. Walk back out to it, turn the key, CEL comes right on (unusual, because it usually takes a sec), cranks and cranks. Ok, pedal to the floor, crank a few times, nothing. Ok, pedal to the floor, crank a few times and lift my foot while cranking...fires up and stalls almost immediately. Repeat this a few times, eventually I manage to time it right and it fires up and stays running. Burns some straight up gasoline exhaust, trips the O2 sensor (it ended up going off), and runs rich for a few minutes before the exhaust clears up. Let it sit and run and warm up completely and took it for a drive, no issues.
Any thoughts or ideas on this? I'm thinking that maybe the fuel pump is on the way out, and the only reason for me to think that is the instantaneous loss of power that I observed when it stalled and because I sort of had to pump the pedal while cranking to start it. Also the CEL comes right on every time now when I turn the key, no waiting.
All suggestions are welcome, I'll have a chance to look at it and do whatever to it in the next couple days. Thanks.
OH WAIT. WHAT?
The Rat is offline
post #2 of 192 Old 11-27-2011, 02:55 PM Thread Starter
The Rat
AND, almost forgot this, to make things weirder...when it first started up and was running smoothly the daytime running lights didn't turn on immediately, they took a few minutes. Can't even explain that one, at all.
OH WAIT. WHAT?
The Rat is offline
post #3 of 192 Old 11-27-2011, 02:57 PM
94chb
sounds like a spark issue and not a fuel issue, i would change the cps and do a tune up.
94chb is offline
post #4 of 192 Old 11-27-2011, 02:58 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Since the first issue was the CEL not lighting up as it should that is where I would concentrate. First check the plug to make sure you have a good connection. Then I would consider doing the PCM repair that is well documented here and a bazillion other places you can find on the 'net. Once you get the CEL to light up when it should see just what else this YJ does before you go throw a box of parts at this YJ......and screw it up real bad! JK!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 192 Old 11-27-2011, 03:03 PM Thread Starter
The Rat
Originally suspected the crank sensor as well, just didn't make sense why it would consistently start when I pumped the pedal while cranking. The tune up is tentative anyway, just managed to pick this one up a week ago so I haven't gotten around to doing the oil change/plugs, wires, cap, and rotor/fuel filter/etc. Been working out great up until the other day.
OH WAIT. WHAT?
The Rat is offline
post #6 of 192 Old 11-27-2011, 03:04 PM Thread Starter
The Rat
I think the CEL wasn't lighting up before due to an iffy connection. I messed around with the connectors (unplugged them and cleaned off a bit of corrosion) as well as the grounds, before noticing that the light was coming right on.
OH WAIT. WHAT?
The Rat is offline
post #7 of 192 Old 11-27-2011, 03:36 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
So since the connections have been cleaned the CEL comes on properly all the time? Not even once has it delayed to come on?
The next thing I would consider is the inline gas fuel filter. If you do not know when it was changed then it needs to be changed!
post #8 of 192 Old 11-27-2011, 03:37 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Next I would consider fuel pressure. Either the pump or the fuel pressure regulator could be the problem if low fuel pressure is the problem. Fuel pressure gauge time....
post #9 of 192 Old 11-27-2011, 03:59 PM Thread Starter
The Rat
Yup, CEL never hesitates now, on as soon as I have the key in the on position (however it does go off after a few seconds, I don't recall if it should or not). Gonna do all the routine stuff to it this week provided that I don't have too much hw and then hopefully all will be well. So annoyed that it just happened all of a sudden.
OH WAIT. WHAT?
The Rat is offline
post #10 of 192 Old 11-27-2011, 04:07 PM
94chb
yes its normal for the cel to come on for 2-3 secs then turn off.
94chb is offline
post #11 of 192 Old 11-27-2011, 04:39 PM Thread Starter
The Rat
Gracias.
Been a couple years since my last YJ ownership.
OH WAIT. WHAT?
The Rat is offline
post #12 of 192 Old 11-27-2011, 05:20 PM Thread Starter
The Rat
Update on this: Hot start it fires right up. Let it sit for a few hours and go out there again, needs me to finagle it to get it to start. Not sure what that translates to.
OH WAIT. WHAT?
The Rat is offline
post #13 of 192 Old 11-27-2011, 05:33 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Translation for finagle??
I figure fuel pump issue would happen all the time or after a bit of driving once the fuel pump heats up.
Maybe you should dump the learned memory in the PCM and go from there.
post #14 of 192 Old 11-27-2011, 05:42 PM Thread Starter
The Rat
By finagle I meant the same as what I did before, pump the pedal while cranking. But if the fuel pump was an issue it wouldn't even run smoothly or anything, once it's running it works just fine. Except for when it stalled out, which has only happened a few times.
Definitely think it just decided to get dumb on me because it knew I had a week with less homework than usual.
OH WAIT. WHAT?
The Rat is offline
post #15 of 192 Old 11-27-2011, 05:53 PM
94chb
sounds like a tune up is needed and filter change.
sidenote: hows the 35's and dana 35 with 3.07 gears holding up?
94chb is offline
no spark
Starting problem cmandes13 TJ Wrangler Technical Forum 6 12-09-2010 05:52 PM
YJ 92 4.0 Starting Problem freebird YJ Wrangler Technical Forum 0 11-08-2010 12:53 AM
Starting problem, '95 4.0 in an 83 CJ7 FOTOPHREAK YJ Wrangler Technical Forum 0 04-25-2007 06:55 PM
Starting problem... 88 YJ 4.2L Quick636 YJ Wrangler Technical Forum 2 11-07-2005 12:47 AM
Help with starting problem! Snowman01TJ TJ Wrangler Technical Forum 4 11-24-2004 07:30 PM
