Need some help with np231 shifter - JeepForum.com
post #1 of 8 Old 05-25-2013, 11:01 AM Thread Starter
herb97tj
Ok so I bought my yj with a 3 inch body lift n a messed up t-case. Picked up a 231 from a tj and threw a slip yoke on it. I also did a 2 inch motor lift. I know may have been a little over kill. Now I have the shift linkage bar from the yj and the tj and neither one hook up. Oh and I'm also working on a belly up skid plate as we speak. Welding in my crossmember in a few. But I wanted to get this linkage hooked up before I weld everything. Any advice would be greatly appreciated.
herb97tj is offline
post #2 of 8 Old 05-25-2013, 11:13 AM
crackedcornish
perhaps if you told us why the linkage from the YJ won't "hook up"...(I'm suspecting because the TJ's 231 case doesn't have all of the bolt bosses the older cases have)
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 8 Old 05-25-2013, 02:49 PM Thread Starter
herb97tj
The yj linkage is to short and the tj linkage is to long
herb97tj is offline
post #4 of 8 Old 05-25-2013, 06:49 PM
bigbossd1030
Can you post a couple pictures of your problem. When you say too short are you saying that it won't clear the bottom of the tub or that the bolts don't line up?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #5 of 8 Old 05-26-2013, 09:25 AM Thread Starter
herb97tj
Bolts don't line up. Il see about getting some pics
herb97tj is offline
post #6 of 8 Old 05-26-2013, 04:18 PM
youngjeepr
Can you make your own? That's what I did.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #7 of 8 Old 05-26-2013, 06:01 PM Thread Starter
herb97tj
That's the route in thinking about going. Got any pics
herb97tj is offline
post #8 of 8 Old 05-26-2013, 08:23 PM
codefiant
I'm using this thing from Novak. Does the job and is pretty adaptable.
http://www.novak-adapt.com/catalog/shifters/sk2x.htm
1988 Wrangler w/ Chevy 5.3L V8
codefiant is offline
