need some help on my 4.0 head swap! - JeepForum.com
post #1 of 17 Old 02-17-2010, 09:57 AM Thread Starter
orichierich
I have a couple of questions for the swap experts: (1990 yj 4.2 with a 1993 xj head and wiring harness)
1. I have swapped the head, done 60% of the wiring, and I used the donor coil and distributor, so the wiring for the alternator is now for the 4.0. How do I make the 4.0 alternator fit with the 4.2 bracket or what alternator can I get that will fit with the 4.2 bracket and still use the 4.0 wiring?
2. I would prefer to use the in tank fuel pump and sending unit, I have looked and my gas tank has a round opening on the top and the 91+ wranglers have the rectangular opening, has anyone or is there a way to adapt the 91+ pump and sending unit to work in my tank? I have seen a few modifications to cj tanks online where they opened up the hole a bit to fit the gm pump and sending unit in. so I was wondering if anyone has done what I want to do.
Thank you in advance.
Richie-
STOCK JEEPS (used to) RULE!!!!!!!!!
Originally Posted by RikRotorhead
Why.... some of my best friends have round headlights.
Originally Posted by Jeebs View Post
Dang! I guess thats why they're affectionately called ProCrap!
orichierich is offline
post #2 of 17 Old 02-17-2010, 10:54 AM
wendell
1987 YJ Wrangler
I can't really help you, but to avoid those kinds of problems. I swapped on the 4.0 head and went with the offy intake and holley 4 barrel setup. The holley TA 4 barrels are built for off road and will take some extreme angles. Also there's no computer or sensors to worry about. I've found this setup to be reliable and capable, easy to maintain. I known it's too late to go back. Some one will be a long to give you some advice. Good luck with it.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #3 of 17 Old 02-17-2010, 11:05 AM
DivineKaos
A 4.0 or 2.5 alternator should line up perfect!
I know you want to use an in tank, but I have no experience with that. I simply bought an inline pump and mounted it to the inside of the frame, and am making a 5/16 skid plate just to be safe.
Hope this helps
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #4 of 17 Old 02-17-2010, 11:19 AM Thread Starter
orichierich
Im going to give the alternator another shot. I had modified the bracket to fit the 4.0 alt in, but now its way out of line with the other pullys.
also what inline fuel pump did you buy and use?
thank you both for the answers.
post #5 of 17 Old 02-17-2010, 11:20 AM
RikRotorhead
The 4.0 alternator has to be used because the computer controls the voltage regulator on the 4.0, as opposed to the 4.2 alternator having the internal regulator.
However, the bracket is the issue. The mount for the 4.0 where it connects to the block is different than on the 4.2 mount. Using the 4.0 bracket will not line up on the 4.2 block.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #6 of 17 Old 02-17-2010, 11:28 AM
DivineKaos
I purchased a 25-40psi pump from Princess Auto for $138. It was the only style they stock that I could find.
We used the 4.0 bracket and it lined up..my donor vehicle was an 89 Cherokee Limited. Maybe it was a bit different?
post #7 of 17 Old 02-17-2010, 11:32 AM
RikRotorhead
Interesting. Could there be a difference in the block on the earlier Cherokees?
Or maybe the bracket is different on the 89 than the 93 donor vehicle Richie is using.
Maybe a trip to the bone yard is on the schedule eh?
RJC#512
post #8 of 17 Old 02-17-2010, 11:36 AM
DivineKaos
It could be. The Cherokee was a bit different all around, for instance- it is an 89, yet had multi port fuel injection, yet didn't have the 7120 high output head. MPFI wasn't even an option you could get at the time.
It was a one owner vehicle, that they had bought brand new- and they said they had never done anything to it.
Wish I could help more.
post #9 of 17 Old 02-17-2010, 09:56 PM Thread Starter
orichierich
Thank you all for your help, I will search for a 89 bracket and see if that will work, and I called my autozone and they dont carry any of the high output fuel pumps the highest output they had was 9-12psi, I have heard of people using the es2000 and the walbro 255, I was hoping to find a 91 or newer wrangler tank and pump from a 4 or 6cyl. no luck yet.
Thank you again for your help.
post #10 of 17 Old 02-17-2010, 10:33 PM
stoveguy01
4.0 head
I done this same swap on my 89 last year I used the 89 alt bracket and just redrilled one of the holes got it to bolt up fine and works great. you will love it when you get it running. one of the best mods Ive done yet
stoveguy01 is offline
post #11 of 17 Old 02-18-2010, 11:08 AM Thread Starter
orichierich
im going to hit up the junk yard this weekend to look for the 89 bracket, also another question for DivineKaos and stoveguy01, did the donor vehicle you got the bracket from have A/C? I keep seeing alts and brackets for sale on ebay some say W/AC and WO/AC. I was wondering if the A/C made a difference in the shape of the bracket?
post #12 of 17 Old 02-18-2010, 09:26 PM
RikRotorhead
OK we got the alternator problem solved. We modified the stock bracket and got a shorter serpentine belt. Everything lined up and is solid.
Just need to resolve the fuel pump issue.
RJC#512
post #13 of 17 Old 02-18-2010, 09:36 PM
stoveguy01
fuel pump
what I did for the fuel pump is pulled my tank than cut the pick up tube I measured the inside of the tank for depth than mounted the pump so I was just shy that length and reinstalled sending unit the fuel pump wires I pulled the thru sending wiring and its grommet off an old gm sending unit I had on hand and replaced the original hooking the wires to the pump and sending unit has worked flawless for me. only down side if you want to call it that iss when I get below a 1/4 tank and turn sharp to were the fuel sloshes to one side In hesitates from lack of fuel never has died tho I figure it makes a good low fuel warning lol
post #14 of 17 Old 03-03-2010, 10:24 AM Thread Starter
orichierich
I got lucky at the junk yard and found a 1995 yj with the fuel tank/pump complete. I have removed mine and already installed and wired it. my stock wiring on my 90yj had an extra wire to the fuel tank that was powered by the ignition so I cut off the original plug and attached the plug from the 95 so I didnt have to run any wires at all. I used the existing steel fuel lines and had cut the 95 rubber lines from the tank long enough so I didnt have to use any new hose. So I went from a 15 gallon metal tank to a 20 gallon poly tank with a internal fuel pump and it only cost me 53 bucks from the junk yard. Lucky find!!
post #15 of 17 Old 04-12-2010, 02:00 AM
RookieJeeper01
1987 YJ Wrangler
Good thread, did you finish the wiring and get it fired up?
RookieJeeper01 is offline
Head Bolt Torque for 4.0 Head Swap + other ? nfisher50 YJ Wrangler Technical Forum 15 06-04-2016 09:00 AM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
head swap or engine swap? nvjeep YJ Wrangler Technical Forum 0 06-15-2009 09:45 AM
4.0 to 4.2 Head Swap jeepxj2007 YJ Wrangler Technical Forum 2 09-17-2008 07:09 PM
head gasket, head swap, 4.0 or stroker sailor77 YJ Wrangler Technical Forum 3 02-25-2005 04:06 PM
