Need some advice on this used engine - JeepForum.com
post #1 of 7 Old 04-08-2010, 11:23 AM Thread Starter
91wrangleryj
I bought this used engine from ebay.
Jeep Wrangler 4.0 Engine Cherokee Motor 88k Complete : eBay Motors (item 250601753829 end time Mar-24-10 20:04:27 PDT)
I just want a good running used engine that I can put in my project jeep. The ebay listing said it ran good with no smoke or tapping. Ok, sounds good.
When the engine arrived it was on its side and the pallet was damaged.
On closer inspection there is fresh oil around the head. Should I be worried about this or is it because it was shipped on its side?
Also on the back of the engine there is an metal piece that is split. Will this cause problems mounting to the transmission?
Thanks for any advice you can give. I'm worried I bought a bad engine.
91wrangleryj is offline
post #2 of 7 Old 04-08-2010, 11:48 AM
frank-id
The engine looks great
If the engine was not pressure washed or cleaned, any oil looks like typical use. The round bushing that is bent can easily be repaired or get one from your bad engine. How much did ya pay for engine? Cost of shipping? I got an engine 4.0l HO for $600 no manifolds. Mine is good. Frank
frank-id is offline
post #3 of 7 Old 04-08-2010, 11:56 AM
KA24DET95
looks fine to me from what i see in the pics
KA24DET95 is offline
post #4 of 7 Old 04-08-2010, 11:59 AM
MLJeeper
MLJeeper's Avatar
Yeah thats just an alignment bushing, as for the oil, thats normal crap. I would rather get it not pressure washed so you know they didnt blow any seals or water into the engine.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 7 Old 04-08-2010, 12:02 PM Thread Starter
91wrangleryj
Cool, thanks for the feedback. Your advice means a lot. Much appreciated.
post #6 of 7 Old 04-08-2010, 12:28 PM
Bastidjeep
Fix the dowel pin and your good to go. I wouldn't sweat it.
Bastidjeep is offline
post #7 of 7 Old 04-08-2010, 02:19 PM
Brown Dog
Vendor
Brown Dog's Avatar
I'd slap it in and run it.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
My Jeep ate its engine ! - need advice on engine swap... ymibuyingmore YJ Wrangler Technical Forum 5 05-03-2011 03:31 PM
2002 with bad engine, advice please JeepDrivr93 TJ Wrangler Technical Forum 3 03-23-2010 04:27 PM
Need engine advice SEZARO21 YJ Wrangler Technical Forum 5 04-13-2009 02:13 PM
engine swap, any advice? gman30 YJ Wrangler Technical Forum 2 10-09-2008 10:04 AM
Need Advice on Engine Skid... MPowerM3 TJ Wrangler Technical Forum 24 02-18-2005 08:38 AM
