In need of some advice for a new yj owner - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > In need of some advice for a new yj owner
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeROGUE FAB Drill Press Reduction Kits – 1:2 and 1:4 ratios Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-23-2012, 05:28 AM   #1
jwellsjr1990
Hey guys I’m new to the forums so don’t bash me up to bad with my noob questions lol. I just bought a 88 yj jeep a few months ago and its in alright shape nothing i can complain about for a 24 year old jeep. The floor pans need to be replaced as i can stick my foot through the floor a Flintstone it if i wanted to. I'm not sure were the best place to get new ones would be if anyone knows a good place let me know please. Oh and one more thing the seat belt bracket that goes to the floor is rotted out to I’m not sure if its the rear floor pan or something else. Could someone enlighten me on this to?
jwellsjr1990 is offline   Reply With Quote
Unread 05-23-2012, 05:50 AM   #2
pete1991YJ
Hi, welcome to JF You've just found one of the best jeep sites anywhere!
2 places I know have just about everything you could imagine:
www.quadratec.com
and
Morris 4x4 at www.jeep4x4center.com
Not sure about the belt tho. Hope that helps!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
91 YJ 2.5L 5-spd, 31" BFG ATs, mostly stock NO RUST 160K in WNY, Daily Driver
pete1991YJ is offline   Reply With Quote
Unread 05-23-2012, 07:27 AM   #3
mitchs1224
congrats on jeep and finding this site. everyone on here for the most part is very helpful, it depends on how handy you are? floor pans are not that hard to fabricate its really just sheet metal depending on how fancy you want to get, when i was kid my dad fabbed some for a mustang he was refurbing out of the side of an old dryer.. i made some for my father in laws 67 Mg about a year ago , its just flat metal that you can have rolled by metal roller at any metal shop which will put little ridges in it length ways to stiffen it or you can cut some out of a donor car it really doesn't even hafto be out of a jeep, just cut them out a little bigger than you need then trim to fit, you can weld or rivet them to the good metal you cut back to when you cut old ones out or just go over the existing ones as longs you've done something to stop the rusting process. from spreading. you can buy replacements too. but if your handy tis def a project you can do. remember its a floor!! its not like your replacing metal in the middle of the hood. as far the sestbelt same deal just needs to be reinforced obviously with heavier metal backing.
mitchs1224 is offline   Reply With Quote
Unread 05-23-2012, 09:44 AM   #4
Que89YJ
Welcome to the forum! They pretty well covered it. I am finally redoing my tub as well. It's the first time doing the body stuff so I only hope I can get it done and make it look somewhat respectable. Keep us updated.
Que89YJ is offline   Reply With Quote
Unread 05-23-2012, 05:55 PM   #5
jwellsjr1990
Thanks guys! so far ive been reading alot of the threads and im learning quite a bit. I just got a MC 2150 carb im gonna install over the weekend if the weathers good. pete1991YJ the websites you gave me are pretty good alot of things i found the floor pans i needed so i will hopefully order them soon still not to sure about the seatbelt problem but ill figure it out. Ill keep ypu guys posted as soon as i get the floor pans in. thanks again for the help!
