Quantcast Need Serious Headlight Help!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Need Serious Headlight Help!!
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 01-15-2005, 07:55 PM   #1
MuddyWrangla
My friggin headlights randomly shut off at night when i'm driving, not only is this dangerous but it pisses me off. I'll just be drivin along and they will shut off, then i fiddle with the switch turning it on and off, i took the switch out and cleaned and tested it and i works fine, what else could it be please help!?
MuddyWrangla is offline   Reply With Quote
Old 01-15-2005, 08:42 PM   #2
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
replace the switch. mine did the same thing and even though the switch checked out fine, it was still the cause. as it heats up under load it starts acting up. cold it works fine. only 25 bucks from the dealer.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote
Old 01-15-2005, 08:56 PM   #3
atomicmoose
Just call me Moose
atomicmoose's Avatar
I have this problem with my driving lights...it has turned out to be a loose connection in the fuse cluster. I wiggle it around and they come back on. Go figure...
atomicmoose is offline   Reply With Quote
Old 01-16-2005, 12:18 AM   #4
Dembones
Good way to tell: Does the switch get hot to the touch? If so then that's your problem.
Blue '94 Wrangler, 2.5L: Under monsterization
37" Claws/teralow/HPD44/Trussed HI9/5:38s/detroits/SOA, shackle reversal on rebuilt waggy and XJ springs.
Blue Jeep Club member 2
Much more info here
Dembones is offline   Reply With Quote
Old 01-16-2005, 01:25 AM   #5
BamaJeeper
Replace the switch.
Out of the darkness comes light.
BamaJeeper is offline   Reply With Quote
Glock Forum
