Need replacement rear shackle mount to weld into frame - JeepForum.com
post #1 of 3 Old 06-16-2010, 09:46 AM Thread Starter
Nate M
Should I just use cut tubing or is there a part sold by a Jeep company that I could buy for this repair? My rear shackle mount which goes through the frame recently tore loose so I need to do a frame repair in the back and will probably replace the rear cross bar at with something heavier at the same time...thinking I should get the shackle mounts sourced before I start my project.
Thanks,
Nate
98 TJ sport 4.0 manual 3"BL (I did not put it on) 35 12.5 MTR
Nate M is offline
post #2 of 3 Old 06-16-2010, 10:00 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Just use tubing. I can't remember the I.D. off hand but all you need is some tubing.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 3 Old 07-06-2010, 08:06 AM Thread Starter
Nate M
Thanks Rusty...I think im going to weld in a section of frame and replace the rear 12 inches or so of mine. I think I will also splice in a more robust rear cross member at the same time.
Nate M is offline
anyone have frame mount rear shackle tabs? aalbinger TJ Wrangler Technical Forum 0 06-09-2010 11:29 PM
frame fix. new rear section, or weld on new plates? headstrong50 YJ Wrangler Technical Forum 18 03-12-2010 12:59 PM
Frame Rotted at Left Rear Forward Shackle dubbletime YJ Wrangler Technical Forum 7 01-26-2009 09:28 PM
More stress on shackle frame mount with lift? Exparrot YJ Wrangler Technical Forum 2 04-25-2008 10:43 PM
Rusted Rear Frame/Shackle mounts runnwild1 YJ Wrangler Technical Forum 3 07-24-2003 11:36 AM
