need to replace Peugeot trans - JeepForum.com
post #1 of 2 Old 09-12-2001, 06:49 PM Thread Starter
tonyxjyj
Any info on what trans to use in place of the
Peugeot (puked again) PROs\Cons T5 nv4500
autos
Thanks
87 yj 4"pro comp,31x10.5wild trac
tonyxjyj is offline
post #2 of 2 Old 09-12-2001, 08:32 PM
Nightclaw
Borg-Warner T5: Made of glass. These suckers just don't hold up, either in Jeeps or Mustangs. Almost as bad as the Peugeot, IMHO. Stay far, far away if possible. Standard equipment on late-model CJ7 (1981-1986).
New Venture Gear NV4500: w00t! The ‹bertranny - if you have the fiscal wherewithal to actually purchase one, get a custom driveshaft and do the body pan mods to fit it under your truck. If you have enough dead presidents to make it happen, don't even hesitate.
New Venture Gear NV3550: Not as beefy as NV4500, but worlds better than the T5 or Peugeot. May or may not be better than Aisin AX/15, and I don't know if any bell housing/xfer case/body pan mods would be necessary. Standard equipment on 2000+ Wranglers.
Aisin AX/15: Mainstream price tag, and will hold up OK, but you'll need to change the Xfer case input shaft to a 28-spline shaft (I could be wrong - correct me if so). Standard Wrangler tranny from 1990-1999.
Nightclaw is offline
Asian or Peugeot trans 89 YJ 4.2? veestan YJ Wrangler Technical Forum 7 03-24-2008 11:27 PM
tj auto trans swap/replace? dynomite117 TJ Wrangler Technical Forum 6 02-03-2008 11:14 PM
BA/10 Peugeot? Ironhead00 YJ Wrangler Technical Forum 3 07-13-2002 02:11 PM
BA/10 Peugeot? Ironhead00 YJ Wrangler Technical Forum 1 07-03-2002 11:22 AM
