Need rear seatbelt info from family style roll bar.. - JeepForum.com
post #1 of 18 Old 05-01-2008, 09:03 AM Thread Starter
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I did my searching and reading for a bit today and have come up with nothing. What I need to know is, where is the lower mount for the 3 point shoulder belt located on a 92-95 YJ??
Is it on the floor like the lap belts are mounted or did they get mounted thru the fender wells??
Also, do the two female buckles share one center bolt, like the lap belts or are they separate??
A pic of the mount from inside and out would be great.
I scored a pair of 99 TJ rear belts and want to get them mounted in today.
Thanx guys,
-Rusty
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #2 of 18 Old 05-01-2008, 09:10 AM
YJames90
YJames90's Avatar
dosent it mount where the male part of the lap belt is now? . I will be doing the same soon, Im not at my jeep now so i cant look
My 2.5 to 4.3 swap thread
YJames90 is offline
post #3 of 18 Old 05-01-2008, 09:32 AM
LilViper95
LilViper95's Avatar
Rusty, on the 92-95 models they belt anchored thru the inner fenders. I cant recall on the center. I just added these to my 90 and I put the centers both in the existing hole. I was too lazy to drill the inner fenders and weld a plate/nut to the outside so I used the existing anchor holes in the floor... seems to work ok! If I hadnt already put the hurculiner in I would have drilled the inner fenders and welded a backing plate/nut. Good luck!
04 Ram 2500 5.9L 24v HO Cummins
LilViper95 is offline
post #4 of 18 Old 05-01-2008, 10:03 AM
BadAddetude
The center female buckles share a common bracket with a torx bolt in them. Should be a hole in the center/slightly rear cardgo area for them.
Shoulder straps:
-Spool (black recoil thingy) mounts on the fender, by the rollbar
-top pivot point mounts on the rollbar
Help any? Sorry no pics.
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
post #5 of 18 Old 05-01-2008, 10:11 AM Thread Starter
rustywrangler
Shoulder straps:
That helps some. On the roll bar I picked up the retractor mounts directly to the roll bar.
As far as the tub mount, so it sounds like I could just mount them to the stock locations. Do you by chance know the distance up the fender well that the stock location is located?? I can fab up a backing plate/nut fairly easily. I just want to have it in the proper location safety wise.
post #6 of 18 Old 05-01-2008, 10:25 AM
QuantumYJ
I agree Rusty, retractor mounts directly to roll bar, I had to open up a new hole for the tab that keeps them from rotating for the TJ belts though. Common, center mount for the females. I wish I could give you measurements for the fender well but the jeep is home
I've been on the internet too much lately. Now, even I'm beginning to think that "breaks" are what you use to stop your Jeep.
QuantumYJ is offline
post #7 of 18 Old 05-01-2008, 10:32 AM Thread Starter
rustywrangler
Yea, it looks like the hole for the tab on the '95 bar I got is gonna be too small as well. Dremel it is.
post #8 of 18 Old 05-01-2008, 10:35 AM
Blazin Den
i just got out of a final and i went out to the jeep real quick i think i took the rights pics for you to get an idea.
take a look here and see if this is what you wanted or not.
http://s248.photobucket.com/albums/g...300/1995%20YJ/
and i realized that i need to clean the jeep out.
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #9 of 18 Old 05-01-2008, 10:39 AM Thread Starter
rustywrangler
That is exactly what I needed to see. I already know what to do for a backing plate so that is taken care of. Your pics helped a great deal. Looks like I will be drilling about 5"behind the rear seat mount.
post #10 of 18 Old 05-01-2008, 11:28 AM
BadAddetude
Forgot all about the strap mounting to the bottom of the fender. Sucks being 70 miles from my Jeep.
post #11 of 18 Old 05-01-2008, 12:10 PM
YJames90
YJames90's Avatar
Must be a big backing plate on the fender mound to hold up to crash tests
YJames90 is offline
post #12 of 18 Old 05-01-2008, 12:14 PM Thread Starter
rustywrangler
Actually not really, all you need is about a 1.5" x 3" 3/16thick plate and it will hold up like it was built into the frame tube.
post #13 of 18 Old 05-01-2008, 08:48 PM
QuantumYJ
I assume you have your holes drilled and the seatbelts installed already but just in case?
I got 2 3/4" up from the floor and 10 1/2" forward from the inner, rear of the tub on those fender well seat belt mounts.
post #14 of 18 Old 05-02-2008, 12:42 AM Thread Starter
rustywrangler
Thanx man. I actually got everything mounted up BUT those holes done. Got rained out. So that info helps a great deal.
-Rusty
post #15 of 18 Old 01-23-2013, 05:51 PM
uhohthe50
I'm reviving this thread since I have the same question. Can anyone post up pics again? It looks like Blazin Den's seatbelt photos aren't there anymore
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline
Family Style Roll Bar Cards89YJ YJ Wrangler Technical Forum 3 12-24-2009 12:44 PM
new family style roll bar and top ImpactFabWorks YJ Wrangler Technical Forum 5 06-19-2009 07:55 PM
Putting the family back in family style roll bar YJames90 YJ Wrangler Technical Forum 12 04-27-2008 04:56 PM
Family style roll bar YJames90 YJ Wrangler Technical Forum 18 09-07-2007 02:55 PM
Where to get Family Style Roll Bar max3k YJ Wrangler Technical Forum 16 05-25-2005 07:37 AM
