Need quick advise on a motor swap - JeepForum.com
post #1 of 4 Old 10-31-2013, 01:02 AM Thread Starter
ericb269
1987 YJ Wrangler
Sup buddies need some advise from the jeep experts on here. I can get a complete 89 xj with a 159000 miles on it for 500 bucks question is would this be a good candidate for a swap into my 87 yj. My yj factory harness has been hacked to all hell and I have a ax15 5 speed in my yj currently . Can you is sootmeyour thoughts good or bad and any issues I may have please.
ericb269 is offline
post #2 of 4 Old 10-31-2013, 02:40 AM
SeanB95YJ
I know some will probably tell you to hold out for a 91+ which will be the HO with the MOPAR computer, but I'd say if it runs well and doesn't smoke, go for it
the 87-90 4.0s in XJs had the RENIX computer (Renault/Bendix collaboration). some people bad-mouth it, but I personally liked them. I had an 87 XJ and that thing was a beast. easily the most reliable motor I've had in a vehicle (so far anyway). Some will point out that the 91+ with the "HO" designation has more horsepower. in reality, the HP difference between the 2 is minimal... the 87-90 were rated right around 175 and the 91+ around 190hp.... but what they fail to mention (either because they aren't aware or they just choose to omit it to make their HP argument more valid) is WHERE the HP and torque peak is achieved...
1987-90: 177 hp at 4500 rpm and 224 lb·ft at 2500 rpm
1991-95: 190 hp at 4750 rpm and 225 lb·ft at 4000 rpm
so while HP peaks pretty much the same RPM, torque for the 87-90, at only 1 lb-ft less comes in at a much more usable location for street and off-road use
my 87 had about 350,000 miles when I got rid of it about 12 years ago due to uni-frame rot... sold it to a guy who pulled the motor to swap into his XJ and last I heard about 5-6 years ago the motor was still going strong
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 4 Old 10-31-2013, 07:36 AM
Que89YJ
Absolutely get it! That is cheap! The swap is so similar the renix just requires adjustments. The Cherokee Renix is even multiport unlike the 2.5! Not only yes, but hell yes. You need 2 High pressure fuel lines all the way to the front and a gas tank and skid plate from a 91-95 YJ.
Que89YJ is offline
post #4 of 4 Old 10-31-2013, 10:12 AM Thread Starter
ericb269
1987 YJ Wrangler
Sweet I think I am gonna pull the trigger and buy it I just went and looked at it and the thing purrs like a kitten . I'll be hitting the forum up for more advise on the swap as I get started thx against guys
ericb269 is offline
