Can someone smarter than myself post a picture of a power steering pump? I have an 88 YJ with the 2.5 (the straight four...)
I would like to see one that shows how the tank is mounted to the pump. I had to take the belt off to change a fan clutch and when I put the pump back in place, the tank started leaking. When I look behind the pulley, I only see one bolt going into the tank from the front. Knowing me, if I couldn't get the bolt back on and thought they were just a bracket bolt, I probably left it off, thinking one would be enough.
Naturally, I'm assuming that if all the bolts didn't get put back in, then the tank isn't sealing where it meets the pump. Can somebody show me what it SHOULD look like behing the pulley?
Jeff
