Need a pic from anyone with a 1987 to 1990 YJ with A/C - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Need a pic from anyone with a 1987 to 1990 YJ with A/C
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 06-25-2009, 01:26 PM   #1
ElvisV04290
I need a picture of the connector(s) for the under dash unit of the A/C. I have the under dash assembly from a '93 but it does not have a connector that works with any of the three wires I can find hanging under my dash. More importantly I need to know where that bundle of wires comes out of the main harness so I can try and find mine. Thanks to anyone that can help.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com
Weber 32/36 Install -> http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/
Early YJ Club Member #37
For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite
ElvisV04290 is offline   Reply With Quote
Unread 06-25-2009, 01:28 PM   #2
Louie4
Injanir
Louie4's Avatar
I have a '93 and I bought a blower motor for your year model because it was $70 cheaper. I wired it up. Now I only have med and high blowing. I went through all the wires on the blower motor testing them to figure out which did which and then rewired it to my harness.
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Unread 06-25-2009, 02:53 PM   #3
ElvisV04290
Ok, I did some poking around and found my Haynes repair manual to check the wiring diagram. And It would appear that 87 to 95 use the same connector for the under dash unit. Now the only issue it that I cant fine it under the dash, and its not to easy of an angle to look at. Anyone know where it would be tucked away since its not hanging free? I would think that I must have it, I have all the other connections needed in the engine bay. I'm going back out to inspect the dash again in hopes of finding it...
Weber 32/36 Install -> http://www.jeepforum.com/forum/showthread.php?t=382309
Unread 06-25-2009, 03:42 PM   #4
Fernando
Fernando's Avatar
1987 YJ Wrangler
I have an 87 with factory AC, I am going to have it fixed soon along with my heater, I don't understand very well what you are asking for but I can take pics of mine if you explain a bit more (for dummies style hehe)
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline   Reply With Quote
Unread 06-25-2009, 03:51 PM   #5
dodger889
Are you talking about the A/C or the heater fan. A/C comes from the rotary switch to the fan and it also turn the compressor too.You have to drop it and then pull the cover off to get to anything. You will have two wires that exit one is power and the other signal for the compressor. Ground through frame.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Unread 06-25-2009, 04:24 PM   #6
ElvisV04290
I think some pictures might help here since I seem to be a little confusing.
This is what I have (along with all the the other A/C stuff)
That part needs to go under the dash (already know that) the blower is mounted to it and connects to a wiring harness on the under dash unit. What I need to figure out is where the connector is on the Jeep to plug the under dash unit into the existing harness in the Jeep. I was told all Jeeps got the same harness (for accessories) no matter what they had installed, so every connection should be there under the dash somewhere...
This is the connector on the A/C dash unit and I need to find the other end of this somewhere on the underside of my dash and am having no luck.
Unread 06-25-2009, 04:36 PM   #7
Fernando
Fernando's Avatar
1987 YJ Wrangler
When I get off work I will take a look
Unread 06-25-2009, 05:50 PM   #8
surfthedrum13
Jeep with A/C...hmmmm strange concept. You should just get a Honda, they have good A/Cs and get better gas mileage.
'95 YJ, 4.0L, 5spd., paying for school...edit, out of school trying to get a job to pay for school...edit, have a job, now I don't have time.
[]|||||||[] Red Jeep Club Member #497
surfthedrum13 is offline   Reply With Quote
Unread 06-25-2009, 05:56 PM   #9
ElvisV04290
This isn't an "A/C or not to A/C" thread.
Unread 06-26-2009, 01:48 PM   #10
dodger889
When I get home I will check also.
Unread 06-26-2009, 02:01 PM   #11
hdfxrs91
1987 YJ Wrangler
Are you adding A/C or replacing the under-dash unit? My 1987 had dealer-installed A/C and it was a mess. If you do not have factory air, this may be why you cannot find the harness you are looking for.
hdfxrs91 is offline   Reply With Quote
Unread 06-26-2009, 02:12 PM   #12
Fernando
Fernando's Avatar
1987 YJ Wrangler
Some of us use our Jeeps as daily drivers, and we have no interest in owning any other vehicle, plus I would like all systems on my Jeep to work, and have it running as good as I can, even if I would not use them often.
Elvis, I did not find that plug on my jeep, not without removing the dash, now, I can loose the screws and take a look tomorrow morning if you do not mind waiting.
Unread 06-26-2009, 02:19 PM   #13
Louie4
Injanir
Louie4's Avatar
I did. I got an '09 Civic AND I have air in my YJ, which I will be converting to 134a in the near future.
Oh yeah, I also fixed the A/C in my '86 civic too. Love that air.
As far as the connector, I thought it was a 4 prong, inline, but I don't have an '89 model so I can't be sure. But I believe I have a blower motor from an '89.
Lou
Unread 06-26-2009, 03:14 PM   #14
Burnerman
Mine doesn't have that connector. It has a Ground,12v power and a wire to the A/C clutch. All of the blower spd wiring is done in the unit. You may not have the connector in the stock Jeep harness...
As for the stud who thinks A/C in a Jeep is useless....good for you. On the hot humid days in a thunderstorm I stay nice and cool and I'll wave to your wet butt. Also when pounding the mud when it's 80* out I keep my top sealed up and the A/C on. The Jeep may stink like a rotten puddle and be covered with mud but I stay clean and cool. As far as I'm concerned it's part of wheeling smart.
To each his own though.. Don't be afraid of technology.....
[SIZE="3"]89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
[/SIZE]
Check my Gallery for pics.
[URL="http://www.jeepforum.com/forum/f12/my-unbuild-rebuild-988762/"]My Rebuild Thread[/URL]
[SIZE="2"][COLOR="Blue"]Take a minute and fill out your profile, Please[/COLOR][/SIZE]
Burnerman is offline   Reply With Quote
Unread 06-26-2009, 03:24 PM   #15
ElvisV04290
hdfxrs91: I'm adding the A/C.
Fernando: You dont need to pull your dash apart, if I can't find the wires I'll just make my own harness. But thanks for the offer.
I'm starting to think that the connector is infact different. I only have three bundles of wires hanging down.
Burnerman: Do any of these conncetors look like what you have going to your A/C? This is all I have hanging down off my dash.
