Need part identified so I can order (bracket to hold up exhaust) - JeepForum.com
post #1 of 12 Old 06-03-2010, 09:10 PM Thread Starter
sloan74
My exhaust is rattling on the skid plate....grrrrrrr
Found the issue but I cannot identify the part in order to buy it.
It looks like a bracket to hold the exhaust up via a u bolt, it's toward the rear before the muffler. It is rubber and one side as snapped, thus letting the exhaust sag very low.
I attached some pics to help you guys.
sloan74 is offline
post #2 of 12 Old 06-03-2010, 09:32 PM
ritjobbie
You should be able to find generic rubbers like that in AutoZone, Advance Auto, or any of the big chains.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #3 of 12 Old 06-03-2010, 10:03 PM
Floppy
Floppy's Avatar
twisted up wire coat hanger always works for an exhaust hanger in a pinch also but I would just get the right parts from any auto parts store like mentioned above.
1990 Jeep Wrangler YJ -
2001 Mustang GT Vert (supercharged)
2004 Lincoln Aviator (daily driver)
2006 Yamaha V Star 1100 Custom
1974 Volkswagen Super Beetle (sunroof and 1904cc motor)
1972 Volkswagen Super Beetle (wolfsburg edition)
Floppy is offline
post #4 of 12 Old 06-03-2010, 10:10 PM
ritjobbie
I just looked at the pic again. The METAL snapped, not the rubber. Coat hanger will give you a quick and probably long lasting fix. =)
post #5 of 12 Old 06-03-2010, 10:16 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Am I missing something? I don't see anything broken. Slip metal hook back thru rubber isolator. Done.
Is something broken I can't see? Are you able to photo/show what is actually broken?
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #6 of 12 Old 06-03-2010, 10:21 PM
ImpactFabWorks
I see nothing broken either?????
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #7 of 12 Old 06-04-2010, 04:29 AM
Fatjimi
Not broken. Loop it thru the rubber holder like the one behind it.
Fatjimi is offline
post #8 of 12 Old 06-04-2010, 07:03 AM Thread Starter
sloan74
The rubber has a slit line down the bottom under the hole, you cannot see it in the pic unless I open it, but it's done.
I will take it off, run it down to Autozone and see if they can fix me up with another rubber isolator of some sort if it's that common.
sloan74 is offline
post #9 of 12 Old 06-04-2010, 07:39 AM
YJhobby
Ah... looking closely at the second pic shows a line that suggests a split. Any auto store or muffler shop should have something similar that would work perfectly, just like stated above.
~Steve~
Originally Posted by SnowdogMarc
YJ's don't get stuck....they get temporarily impeeded in their forward progress.
I'm patiently waiting for the "foot-in-mouth" moment to end... but since I've posted, its not today
YJhobby is offline
post #10 of 12 Old 06-04-2010, 10:41 AM
Opihi59
Opihi59's Avatar
RUBBER EXHAUST INSULATORS - JCWhitney
Checker's, O'Reilley, Autozone, etc.
Opihi59 is offline
post #11 of 12 Old 06-10-2010, 08:10 AM Thread Starter
sloan74
Thanks for the help guys. Got a new one at Autozone and got it on the Jeep last night. I cut the old one off to make it easier to remove. To install the new one I put one end on the u-bolt, jacked up the muffler (using a small block of wood in between not to damage it) and slid/hammered the other end of the insulator to the male end of the steel bracket/mount.
Was not that bad, other than NC summer heat in the garage......haha
We can mark this one as resolved. Thanks again for the part ID help.
sloan74 is offline
post #12 of 12 Old 06-10-2010, 10:40 AM
Opihi59
Opihi59's Avatar
I suppose it would have been more helpful to have posted this up earlier, but just got this photo this weekend. Turns out one of mine was broken on another vehicle. Got this at Checker's/O'Reilley.
Opihi59 is offline
YJ exhaust has XJ firing order on it?? Sparkfly88 YJ Wrangler Technical Forum 1 04-11-2010 11:04 AM
Am i missing a bracket for the tailgate used to hold the soft top? BobbySwiz JK Wrangler Technical Forum 5 05-05-2009 08:43 PM
New order "on hold"? JeepingJohn JK Wrangler Technical Forum 13 01-07-2008 09:53 AM
Looking for part to hold visor to Jeep greaneyk TJ Wrangler Technical Forum 7 09-14-2007 03:33 AM
need to know size of bolts that hold the exhaust manifold on in my 2.5L cutlass1972 TJ Wrangler Technical Forum 7 02-27-2006 08:37 AM
