Need a new soft top - JeepForum.com
post #1 of 5 Old 12-17-2011, 10:10 AM Thread Starter
bigunn
Need a new soft top
I recently got a 1995 yj with no top sorta of , just parts and peices . Where is the best place to buy a new top? Also I see that you need some kind of frame work. I have the soft upper door frames, but those little plastic inserts in the door are missing. Thanks for the help.
bigunn is offline
post #2 of 5 Old 12-17-2011, 11:29 AM
scubamc
4WD or Quadratec
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 5 Old 12-17-2011, 12:41 PM
WakeDoctor
Try ebay and your local Craigslist as well.
WakeDoctor is offline
post #4 of 5 Old 12-17-2011, 01:55 PM
mrmud4x4
http://www.jeep4x4center.com/jeep-so...rangler-yj.htm
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #5 of 5 Old 12-18-2011, 01:19 AM
tdij
If you are starting without a bow from an old top look at softtopper.com. Very affordable compared to a new complete bowed top.
After having a roll cage mounted top I would never go to a bowed top. Bowless tops are clean and easy to use.
BOBCAT: TDI powered YJ
tdij is offline
JK Unlimited Standard Soft Top v Sun Rider Soft Top...Pics please SJP-07JKx JK Wrangler Technical Forum 10 07-10-2015 04:43 PM
Soft top question regarding straps coming off the soft top bars. newjeepowner05 JK Wrangler Technical Forum 12 12-30-2013 06:49 PM
Bestop makes 2 piece soft doors which match with Factory soft top? AROSETO TJ Wrangler Technical Forum 9 02-23-2010 11:41 AM
Soft top issue problem solver, must read if you have a YJ soft top marvin51796 YJ Wrangler Technical Forum 9 03-04-2005 12:50 PM
re: do soft top windows from older best top soft tops fit 03 wrangler?? skaboyy TJ Wrangler Technical Forum 3 06-12-2004 01:59 PM
