Need more clearance in the rear - JeepForum.com
post #1 of 9 Old 04-18-2010, 09:52 PM Thread Starter
highrolrcustoms
after doing some flexing i found that i need more clearance in the rear...i am doing tube fenders in the front to help with that but no clue what to do in the rear???? any ideas? i really hate to cut the flares.
AND YES I KNOW MY REAR SHOCK IS DISCONNECTED...IT WAS TO SHORT AT THE TIME OF PICS
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #2 of 9 Old 04-18-2010, 10:07 PM
91YJRockCrawler
get TJ flares then cut the tub.. mine is cut out without flares
The P.O.S: 91 wrangler locked on 33s
Daily Driver/tow rig: 01 F150
its mind over matter.. I donít mind and the sheet metal donít matter
Originally Posted by JeepnBlake View Post
It's JF's very own little slice of Pirate :rofl:
91YJRockCrawler is offline
post #3 of 9 Old 04-18-2010, 10:15 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
There is no way to gain clearance without cutting in your case. Why not match the rear fenders with tubes as well, and open up the wells while you're at it?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 9 Old 04-18-2010, 10:16 PM
provinT13
Well that looks like great flex to me, but TJ flares will get you another inch or so, an inch body will get you another inch, but if you really wanna go all out, just comp cut the sucker.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #5 of 9 Old 04-18-2010, 10:22 PM Thread Starter
highrolrcustoms
i want a clean look and i was thinking about doing the comp cut because i am looking to stretch the wheelbase in the future. already running a 2" body lift. and not that big of fan of the tj flares but i will do what it takes to get more clearance.....i wanna see how much flex i can get out of it and dont want the body to stop it.
ULTIMATE.....i did a search for rear tube fenders but didnt come up with much......any ideas on who makes some decent ones. also how would i open up the wells with tube fenders?
OH AND THAT FLEX IS WITH BRAND NEW 2.5" PROCOMP SPRINGS!!! everyone says they are very stiff but i think they seem to flex pretty good
post #6 of 9 Old 04-18-2010, 11:26 PM
provinT13
For tube fenders with the max clearance, go Metalcloak.
http://www.metalcloak.com/Default.asp
Expensive, but I'm pretty sure they will give you the most clearance out of anything. On a TJ you can run 35's with stock suspension and metal cloak original fenders. Simontuffguy on the forum has 2.5" of lift on 33's with metal cloaks and he could easily fit 35's under there.
post #7 of 9 Old 04-18-2010, 11:57 PM Thread Starter
highrolrcustoms
i really like the metalcloaks but.......$$$$$$ i think i would rather do a comp cut than spend that much especially since i am looking to stretch it in future. anyone else make tube fenders for the rear that i wont have to sell a kidney to buy...
post #8 of 9 Old 04-19-2010, 12:05 AM
provinT13
Nope. If you want clearance from fenders you're going to have to go full replacement. The only other company I would recommend is TnT customs, but they're also very expensive. Go metal cloaks up front and comp cut the rear, add some comp corners from Gen Right
GenRight, COMP Cut Full Corner Guards
Or you could go with the GenRight Hi-Line kit
http://www.genright.com/ProductInfo....ductid=TFF4XXX
Paired with their comp cut corners
post #9 of 9 Old 04-19-2010, 12:39 AM Thread Starter
highrolrcustoms
after checking out genrights website i really like the 4" Hi-flare......
Tube Flares, 4" REAR Hi-Fender
seems like a pretty cheap way to get alot of extra clearance if that is the only thing i need to buy....i was looking at the comp cuts and the only ones they list are for stretch wheelbases and im not ready to do that just yet
Rugger Ridge XHD rear clearance coshooter JK Wrangler Technical Forum 3 07-20-2009 11:08 AM
Inverting Rear Shocks for More Clearance Gymguyjeep TJ Wrangler Technical Forum 9 04-28-2009 03:29 PM
Spare Tire Clearance Problem on a Smittybilt Classic Rock Rear Bumper EugeneTheTJ TJ Wrangler Technical Forum 1 12-28-2008 10:28 AM
Rear shock clearance jeeptraxx TJ Wrangler Technical Forum 3 07-18-2007 08:49 AM
clearance issue on rear? 35" tire vs body Riverdog JK Wrangler Technical Forum 5 05-31-2007 10:56 AM
