Quantcast need info on msd box hookup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > need info on msd box hookup
Old 03-05-2009, 09:57 AM   #1
DODGEN1
have an 87 4.2. they put an msd box on it. in trying to confirm the hook up of the orange and purple wires to the dist. they cut the loom conector out and wired thru it to hook up to the dist. there are tree wires on this conector.which is for the orange and purple wires?
thanks for the help.
DODGEN1 is offline   Reply With Quote
Old 03-05-2009, 10:09 AM   #2
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
More info man. Are you doing a nutter bypass??? Does it run the way it is???
Where exactly did they tie in??
pics????
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 03-05-2009, 11:19 AM   #3
DODGEN1
so all it has is the msd box a coil and the distributer. it has a weber carb.(32/36)?
the msd is hooked up as per the in structions i see from the post nutter bypass that the wires on the dist ar orange, purple and black. so just match the colors?
the ting is it runs like s*** and we cant figure out why.
im assuming that the entire stock electronic ignition has been gutted.
i know nothing about jeeps.
do you need more info?
Old 03-05-2009, 11:23 AM   #4
rustywrangler
Yes, if you have a weber carb and the msd box, it sounds like the stock ignition has been bypassed. Is it a stock dist???
Old 03-05-2009, 11:36 AM   #5
DODGEN1
yes it has been replaced. the original one was wandering around at an idle. but now i think that was because it was hooked to intake vacume.
the weber has not been rebiult but ive done the tuning procedure it idles and revs at no load. when you put a load to it it will not rev up and c**** all over itself.
weve done compresion, wires cap rotor, every thing else we can think of. but it wont run.
Old 03-05-2009, 01:26 PM   #6
timatoe
Jello Puddin'
timatoe's Avatar
There's an MSD connector that will plug in there, then there's an orange and purple wire coming off that connector. The orange one then goes to the purple wire on the MSD and the purple one goes to the green wire on the MSD. I was going to take a pic, but apparently my camera is MIA.
Additionally, I have that connector sitting in the garage if you can't find one local. I no longer run the MSD, also got the same connector for a HEI (if you may upgrade).
timatoe is offline   Reply With Quote
Old 03-05-2009, 01:36 PM   #7
DODGEN1
thanks ill look at that
Glock Forum
