Need info/help - JeepForum.com
post #1 of 3 Old 04-11-2010, 11:41 PM Thread Starter
Azboy
Need info/help
Almost a year ago I pulled the engine/trans/tc out and eventually rebuilt all of them. Alot of things happened that slowed that process but that's a different story. Now that I'm to the point of putting it all back together, I can't remember where those three weird looking bolts go on the front of the motor. Best I remember, they belong to the water pump or the timing chain cover. Neither the FSM or Chiltons talk of them. Looking for info or maybe a diagram, is some one has one.
Azboy is offline
post #2 of 3 Old 04-11-2010, 11:45 PM
Fhajad
Or maybe some pictures? "Weird bolts"?
Fhajad is offline
post #3 of 3 Old 04-12-2010, 12:01 AM
moonshinefuel
If you are talking about weird, I think there are 3 or 4 different sized bolt sockets for that cover alone. They are not all uniform, so yea it's strange in that regard. I think maybe if you did a search on timing chain replacement you might find info there on this, and pictures.
moonshinefuel is offline
Need some info on the 04 4.0 IAC. warsw TJ Wrangler Technical Forum 0 10-31-2009 10:15 AM
need lift info & regearing info stuart2410 JK Wrangler Technical Forum 3 01-18-2009 10:28 AM
Sat ant info nyr1583 JK Wrangler Technical Forum 3 10-05-2007 08:37 PM
Need YJ info BradyAds.com YJ Wrangler Technical Forum 11 10-01-2007 10:24 PM
Factory Warranty info? Top info? BlueRidgeRunner TJ Wrangler Technical Forum 5 06-27-2004 04:52 PM
