I found a leak where the transmission meets the transfer case. Steady drip every 3-5 seconds.
Daily driver - 1992 YJ 4.0 Fuel Injected I6.
TF999 Automatic Transmission and NP231 Transfer case.
I pulled the transfer case thinking it was a seal that had gone bad. Replaced the rear seal on the transmission and all the seals on the transfer case. When I installed the TC everything was fine until I lowered the jack holding up the rear of the TC. Immediately, the exact same spot began to leak again. Almost as if the damn thing waited until I tightened the last bolt.
It's ATF leaking, reddish brown in color. The transfer case is empty of fluids, I haven't refilled. Anyone have any idea what this could be. Besides the leak, there are no symptoms of anything being wrong. If it wasn't for the puddle in the driveway, I might not have noticed until the fluid was low.
