Need help with transmission - JeepForum.com
post #1 of 14 Old 01-22-2006, 12:07 AM Thread Starter
longdecember
Hey I need some help deciding what to do about my tranmission. I have a 1995 Yj with an ax-5. The transmission has been grinding for a while and just last week it got stuck in second and will not come out, just suddenly. No warning. The problem is i don't know wether to rebuild my ax-5, find a used ax-5 which might have the same problems or do the ax-15 swap which would be used and would cost alot. Here in canada, winnipeg actaully i am having huge trouble finding either a ax-5 or ax-15 for under $900. For that much i could easily have my ax-5 rebuilt. I need advice about wether I should rebuild my ax-5 or step up to the ax-15 with external slave. I would be intrested if someone had one for sale.
longdecember is offline
post #2 of 14 Old 01-22-2006, 12:36 AM
Brown Dog
Vendor
Brown Dog's Avatar
Ax5
In my experience, parts for the AX transmissions are very expensive. If there is anything wrong that requires a lot of replacement parts, watch out. I am also NOT surprised at the junkyard prices. If it were me, and I couldn't afford a new one, I would go with the junkyard.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 14 Old 01-22-2006, 07:12 AM
1992 renagade
I bought my AX-15 off of e-bay from www.mantrans.com . I paid $700.00 for it with free shipping. There was a $300.00 core charge that I got back after they got my old trans. I've had the trans since oct. and put about 6 to 8 thousand miles on it with no problems. Mantrans prices were alot better on e-bay vs what
i was quoted on the phone.
Neill
1992 renagade is offline
post #4 of 14 Old 01-22-2006, 12:47 PM Thread Starter
longdecember
I have heard from places that a rebuilt trans is not even close to having the longevity of a non-rebuilt. what is the expected km's out of a rebuilt. If i am going this route i might just stick with my ax-5 and not swap to the ax-15. 1992 renegade you did the swap right was it hard? thanks
post #5 of 14 Old 01-22-2006, 02:53 PM Thread Starter
longdecember
bump to the top
post #6 of 14 Old 01-22-2006, 05:07 PM
wranglerkid16
Neill
i have an ax-15 from them as well, very good company, cheap too, 695 for the tranny, 81 for shipping the core back...well worth the money...ask for bob
wranglerkid16 is offline
post #7 of 14 Old 01-23-2006, 04:20 AM
1992 renagade
No my jeep had a AX-15 in it from the factory.
Neill
post #8 of 14 Old 01-23-2006, 07:45 PM Thread Starter
longdecember
how many km's can i expect out of a rebuilt ax-5?
post #9 of 14 Old 01-23-2006, 07:57 PM
Stang5lgt
Stang5lgt's Avatar
Depends on how hard you drive. But with normal drive you should be able to get 100k miles out of it no prob. Sound like your syncros are were going out and finally did. Shouldn't be too bad for a rebuild. Find a place that has done a few before you let them touch yours.
For Off Road Deployment
Stang5lgt is offline
post #10 of 14 Old 01-23-2006, 09:35 PM Thread Starter
longdecember
thank you stang that is an answer i was looking for i didnt really want to hear any horror stories to tell you the truth, what do you think i should do, buy a rebuild kit and give it to the tranny shop or just get them to order it and do it also.
post #11 of 14 Old 01-23-2006, 10:13 PM
Stang5lgt
Stang5lgt's Avatar
I would ask them they might be able to get you a deal on one. Get a price for one before you go that way you know if they are trying to rip you or not. If they are only a few bucks more then I would go for it. Cause figure the time for you run around and find one plus they might not stand behind a rebuild kit you didn't buy from them. Those are the things you need to think about when saving a few a bucks.
post #12 of 14 Old 01-23-2006, 11:20 PM
STP743
My synco gears went on my AX-5 out of my 95 so I swaped it for a used tranny, out of a 89 I think.
Last weekend my friend did the same, AX-5 was toast, so we swaped it for an older one.
I got mine for 200 CAD within 2 hour drive (including a transfer case and rear driveshaft) 200 000 KM
He got his for 250 CAD within 2 hour drive (just the tranny) 150 000 KM
I have no evidence to back up this comment but I'll throw it out there. The AX-5 tranny changed to an external clutch in (early 90's say 92ish) I seem to hear alot about the post 92ish trannys all failing, and not the earlier ones.
Good luck
2005 LJ Rubicon
on 33s
STP743 is offline
post #13 of 14 Old 01-24-2006, 09:37 AM Thread Starter
longdecember
hey thanks alot, stp743 where exactly in canada are you? im in winnipeg and cant find one for the life of me that isnt 900 dollars.
post #14 of 14 Old 01-24-2006, 10:38 PM
STP743
I'm in London ON (half way between Toronto and Detroit) and most of my used parts come from the Toronto area. There is a site www.jeepkings.ca based in Southern Ontario with frequent Jeeps being parted out, no dealerships, or scrap yards, just Jeep guys/girls helping each other.
2005 LJ Rubicon
on 33s
STP743 is offline
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 04:10 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 07:43 PM
bad transmission? OutDoorDawg TJ Wrangler Technical Forum 12 07-08-2007 04:34 PM
How to tell which transmission you have. GilpinTJ TJ Wrangler Technical Forum 1 06-19-2007 10:41 PM
transmission CRAZYJ1988 YJ Wrangler Technical Forum 12 01-31-2006 01:36 PM
