Need help with starter solenoid *pics* - JeepForum.com
post #1 of 7 Old 11-20-2012, 01:54 PM Thread Starter
atthemattin
1987 YJ Wrangler
so here is my problem, I my jeep was not starting due to the starter solenoid no longer working, in addition to wires with some bad connections. so I got all of the wires fixed and the noid is back in place. well long story short one of the wires i need to connect to the noid was pulled out and now it wont run at all. the jeep runs fine, i have power to the dash but because some ******* tryed working on it before i owned it and has completely butchered the wiring to the starter, i'm having problems trying to figure out where this last wire goes too.
this is what the solenoid, it has 6 hot wires going to the pos end of the terminal and has two lower smaller terminals that has one wire going to each terminal. i can't figure out where this green wire with a white stripe goes.
the green wire is in my hand and it looks like it might have been butt connected to maybe another wire? or maybe it leads into another harness?
here is the older one. i'm talking about the wire that is on the smaller terminal at the bottom, not the larger one at the top that goes to the starter and battery. I can't figure out where the small terminal at the bottom right goes to, the other one is still connected to the original wire, now i just need to get this other one in so i can actually get the thing running
If you guys could help me i would really appreciate it. if you have any photos of your 4.2s and where those wire run too that would help out a lot. the jeeps and 87 with a 4.2, and honestly this is driving me crazy.
thanks a lot
atthemattin is offline
post #2 of 7 Old 11-20-2012, 08:39 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here is what I found:
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #3 of 7 Old 11-22-2012, 01:30 PM Thread Starter
atthemattin
1987 YJ Wrangler
So looking at that pic, I should have five terminals?
post #4 of 7 Old 11-22-2012, 04:11 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
No....you should NOT take any adive from me if I post after 3PM!! That is the coil in those pictures not your starter relay!!! And you are as bad as me for not catching that!! Let me look AGAIn and see what I can come up with......this getting old really sucks
post #5 of 7 Old 11-22-2012, 04:17 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Maybe this is better information......but be suspicious of the source. He is old and abused himseld often and to the extreme and is now tripping out on thryptophan...and it is was past 3 PM!
post #6 of 7 Old 11-22-2012, 05:12 PM
roadyrob
1987 YJ Wrangler
sounds like someone is having fun this thanksgiving.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #7 of 7 Old 11-23-2012, 09:55 PM Thread Starter
atthemattin
1987 YJ Wrangler
hahahaha, yeah I blame myself for not seeing the coil. but this is what i've been looking for. i'll see what i can do with it tomorrow, i really am thankful for you finding this for me. thanks a lot
