Need Help with Starter Relay Wiring - Page 2 - JeepForum.com
post #16 of 23 Old 06-23-2009, 01:06 PM
gsmith795
Originally Posted by USMC_JeepGuy View Post
Check your fusible links and make sure one is not blown. Also, check to make sure your fuses in the fuse block (under the dash) are good as well, then check to see if you have power to the terminals in the fuse block that are involved with starting. If you need diagrams let me know I have some pretty thotough ones I can post.
+1 on the diagrams. I've got a 4.0 with a 93 wiring harness/ecu... so I guess if you've got wiring diagrams that apply to the 93 I'd love to see them
gsmith795 is offline
post #17 of 23 Old 06-23-2009, 03:05 PM
USMC_JeepGuy
Diagrams 87-90
These are for the 4.2 (87-90). If you need something else let me know.
USMC_JeepGuy is offline
post #18 of 23 Old 06-23-2009, 03:08 PM
USMC_JeepGuy
wiring 91-95
These are for the 4.0 (91-95). Included are the ignition switch diagrams. Let me know if you need something else.
post #19 of 23 Old 06-23-2009, 03:11 PM
USMC_JeepGuy
Wiring diagrams
If you would like the complete wirin diagrams for everything send me a pm w/ your email addy and I can mail them to you. I once posted the entire thing but the mods deleted it for copywrite reasons....Let me know!
post #20 of 23 Old 06-23-2009, 04:59 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Thank you so much!! PM sent!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #21 of 23 Old 04-03-2010, 08:13 AM
jschulz85
wiring diagram
could you send me the complete for 89 wrangler 4.2 my email is bigblue174812@aol.com
jschulz85 is offline
post #22 of 23 Old 11-29-2013, 09:42 PM
Oregon4x4
Trying to figure this situation out right now...two part question and I think they may be one to do with the other:
1. Who ever owned it has messed with the wiring and jimmy rigged it so that a Green wire that is hooked to the starter solenoid is not connected to anything up by the battery..so when I touch it to the positive side of the battery with the ignition in the on position it turns over but won't start on its own.
2. In order for me to get the vehicle to start I have to feed it fuel or starting fluid down into hose that goes into air filter....BUT if I hold it open so its rev it up and hold it for about 15 secs (manually from under the hood) then let off it will idle and run great until I need to start it again.
Oregon4x4 is offline
post #23 of 23 Old 12-02-2013, 06:33 AM
Que89YJ
Oregon you need to post up to a new thread. This one is old and please fill out your profile information for your Jeep. It will help us help you.
Que89YJ is online now
Hydrocrbn
88 YJ starter relay wiring diagram brianOU YJ Wrangler Technical Forum 5 01-30-2012 09:48 PM
1987 2.5: starter relay wiring ? hints and tips anyone ? intenseblu YJ Wrangler Technical Forum 8 05-08-2009 09:07 AM
Starter Relay Wiring - Ground Wire Question DocArt YJ Wrangler Technical Forum 4 03-06-2009 06:41 PM
95' yj starter relay wiring diagram jws1961 YJ Wrangler Technical Forum 3 03-26-2008 06:29 PM
88 Wrangler Starter Relay Wiring alex88 YJ Wrangler Technical Forum 2 07-20-2004 08:52 PM
