Need help with spider gear ?? - JeepForum.com
post #1 of 5 Old 10-04-2012, 06:12 PM Thread Starter
brockj
the jeep is at the mechanics now on the hoist. the jeep is a 91 yj 4.0 with 3.07 gears. i bought a set of 4.10's and carriers off someone on jf and we are having them installed. the new gears did not come with spider gears. they are factory gears out of a 4cy. yj. problem is i dont know what year. the spider gears from my 91 i am trying to use in the new carrier are too big of a diameter to seat into the carrier......what do i need, a new carrier or new spider gears? would a carrier with abs ( if the donor jeep was 93 or newer) be a smaller diameter for the spider gears? please help!!!!!
brockj is offline
post #2 of 5 Old 10-04-2012, 06:30 PM
Jeepguy83
The carrier is the only one that will fit 4.10 gears so you'll need spider gears if you opted to keep the Dana 35 in the rear (cheaper to do an 8.8 swap) and either spider gears or a lunchbox up front. Your call.
The carrier changes size and you need corresponding sizes with the spider gears.
Jeepguy83 is offline
post #3 of 5 Old 10-04-2012, 06:32 PM Thread Starter
brockj
just checked east coast gear supply and they have two different sets, 94 and older and 94 and newer.....one is a 1.625 bore diameter and the other is a 1.560 bore diameter. the spider gears i have are a 1.625 bore diameter so i can only assume i need the 1.560. i will still take any input, thanks
brockj is offline
post #4 of 5 Old 10-04-2012, 06:48 PM
Jeepguy83
Forgot about the change. Sorry. Midway through '93 the Dana 35 got a change and they swapped from the 1310 to the 1330 yokes as well. It's been so long as I've seen a Dana 35 intact I forgot about it. You can pull from a Cherokee if need be as they're probably the most plentiful.
post #5 of 5 Old 10-04-2012, 06:49 PM Thread Starter
brockj
will my axle shafts still fit in the smaller bore diameter spider gears?
brockj is offline
