Need help! Replacing water pump in a 2.5 - JeepForum.com
post #1 of 2 Old 06-10-2010, 11:00 AM Thread Starter
ZonaWrangler
You would think somewhere on the web you could find step by step instructions.
Here's where I am at:
1. Remove fan shrowd
2. Undo hoses and drain
3. Remove PS pulley and serpentine belt
Now here is where I am stuck.
Obviously the fan and pulley needs to come off. Now, there are 4 bolts on the back of the fan. I was able to remove those, but that does not allow me to remove the fan. There are also 4 bolts on the pulley, but it moves independantly from the fan, so it seems there is no way to remove those bolts (as the pulley just spins).
So how do I remove that pulley and the fan? Any other tips would be appreciated.
Thanks.
95 Wrangler Rio Grande. Herculined, AEM Brute Force, Helix TBS. No lift, Viper alarm, Primax rims and 30 x 9.5 Dunlop ATs. Gabriel HD shocks. My DD. Mostly ..... mostly.
ZonaWrangler is offline
post #2 of 2 Old 06-10-2010, 11:41 AM
blake989
TJ Water Pump Replacement - 1
this is for a TJ, but your YJ will be exactly the same.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
help replacing water pump!!!! xOakley TJ Wrangler Technical Forum 19 08-30-2009 10:00 PM
Help replacing water pump MercuryTec TJ Wrangler Technical Forum 5 08-22-2009 04:37 PM
Replacing water pump and need help. cb19950 TJ Wrangler Technical Forum 9 09-26-2007 02:24 PM
Replacing water pump tomsjeep TJ Wrangler Technical Forum 3 03-02-2006 07:22 PM
replacing a water pump Mdmann YJ Wrangler Technical Forum 18 04-17-2005 09:54 PM
