Need help, removing nearly all vacuum lines. - JeepForum.com
post #1 of 7 Old 06-29-2012, 01:34 PM Thread Starter
tyler1234567
Edit: forgot to mention I'm doing it at this moment... hands are oily and everything. On my phone now.
4.2 here, nuttered, kinda a straight front axel, ( locked permanently)
Weber carb.
Unavoidably removing egr
I'm yanking all vacuum lines except vacuum advance. Do i have the green light from you gurus? What about this picture I've attached focusing on the five hole device sticking out of manifold
tyler1234567 is offline
post #2 of 7 Old 06-29-2012, 03:18 PM Thread Starter
tyler1234567
Please help
post #3 of 7 Old 06-29-2012, 03:28 PM
evanjeep
2011 WK
All of my holes on that are plugged
evanjeep is offline
post #4 of 7 Old 06-29-2012, 03:33 PM Thread Starter
tyler1234567
thanks!
post #5 of 7 Old 06-29-2012, 03:35 PM
jbolty
jbolty's Avatar
I hope you are not planning for a CA smog cert.
As for the CTO valve, it controls the egr and the charcoal canister purge; there is really no benefit to removing either of those. Here's a stripped down vacuum diagram.
jbolty is offline
post #6 of 7 Old 06-29-2012, 03:48 PM
superj
here is all the vacuum lines on mine but jbolty is right, you need everything for smog. i removed the cto, the egr, the purge cannister, everything but the line for the distributor, hte line for the four wheel drive, and the cruise control vacuum.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 7 Old 06-29-2012, 07:37 PM Thread Starter
tyler1234567
Florida registration, and must remove egr.. no if ands or buts.. but thanks for your advice
