need help quick please. - JeepForum.com
post #1 of 11 Old 03-14-2014, 10:08 AM Thread Starter
chainbreaker
OK I picked up a rear end the other day for 100 and it has a locker in it I'm looking to swap over. My question is since that rear gear has the same gear ratio as mine can I just pull locker out with ring gear and put it straight into mine? Or do I need to swap my ring gear?would really like to get this thing going today. Both have 410 ratio but the other axle has some stuff cut off of it and mine is good.
chainbreaker is offline
post #2 of 11 Old 03-14-2014, 10:17 AM
roadyrob
1987 YJ Wrangler
what type of locker? if its a lunch box like aussie or spartan, yes you can swap it .if its a selectable locker then no.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 11 Old 03-14-2014, 10:20 AM Thread Starter
chainbreaker
Its a lock right
post #4 of 11 Old 03-14-2014, 10:20 AM Thread Starter
chainbreaker
Ty very much
post #5 of 11 Old 03-14-2014, 03:09 PM
Siva283
Thats a lunch box locker. Just swap it over. Do not swap the ring gear. Just the locker.
Ask me how I know...
Siva283 is offline
post #6 of 11 Old 03-14-2014, 04:21 PM
jbeebe
x2 on just pulling the locker out of the carrier and putting it in the other one.
91 YJ. 4.0, 4.10's, 33's, 4" springs, 3/4" booms, 1" BL, 1" MML, d30 aussie locker, hand throttle, posi-lock, full cage, bumpers/rocker guards/engine skid, winch.
jbeebe is offline
post #7 of 11 Old 03-14-2014, 05:49 PM
cwstnsko
Assuming both axles are the same model, ie both Dana 35s, then the locker should swap over, unless your 1988 axle has the factory limited slip (trac-lok) If it does, the lock-right will not work with the limited slip carrier. If your 1988 has limited slip now, then more parts would need to be swapped....
cwstnsko is offline
post #8 of 11 Old 03-14-2014, 07:32 PM Thread Starter
chainbreaker
Its done lol got it swaped over drives great. Thank y'all for advice.next is the lift I got with it for another 100 dollars 4" springs lol
post #9 of 11 Old 03-15-2014, 10:42 AM
XJ93
4" springs? Dang, hope you are planning an SYE with that lift and some steering improvements.
XJ93 is offline
post #10 of 11 Old 03-15-2014, 06:33 PM Thread Starter
chainbreaker
Yes i am i got a zj pitman arm i think will work and getting shocks 1x1 atm. Then im doing sye and a driveshaft.
post #11 of 11 Old 03-18-2014, 01:36 PM
XJ93
Nice, post up some pics when you get her done.
XJ93 is offline
