-   -   need help quick please. (http://www.jeepforum.com/forum/f12/need-help-quick-please-2215185/)
chainbreaker 03-14-2014 10:08 AM
OK I picked up a rear end the other day for 100 and it has a locker in it I'm looking to swap over. My question is since that rear gear has the same gear ratio as mine can I just pull locker out with ring gear and put it straight into mine? Or do I need to swap my ring gear?would really like to get this thing going today. Both have 410 ratio but the other axle has some stuff cut off of it and mine is good.
roadyrob 03-14-2014 10:17 AM
what type of locker? if its a lunch box like aussie or spartan, yes you can swap it .if its a selectable locker then no.
chainbreaker 03-14-2014 10:20 AM
Its a lock right
Ty very much
Siva283 03-14-2014 03:09 PM
Thats a lunch box locker. Just swap it over. Do not swap the ring gear. Just the locker.
jbeebe 03-14-2014 04:21 PM
x2 on just pulling the locker out of the carrier and putting it in the other one.
cwstnsko 03-14-2014 05:49 PM
Assuming both axles are the same model, ie both Dana 35s, then the locker should swap over, unless your 1988 axle has the factory limited slip (trac-lok) If it does, the lock-right will not work with the limited slip carrier. If your 1988 has limited slip now, then more parts would need to be swapped....
chainbreaker 03-14-2014 07:32 PM
Its done lol got it swaped over drives great. Thank y'all for advice.next is the lift I got with it for another 100 dollars 4" springs lol
XJ93 03-15-2014 10:42 AM
4" springs? Dang, hope you are planning an SYE with that lift and some steering improvements.
chainbreaker 03-15-2014 06:33 PM
Yes i am i got a zj pitman arm i think will work and getting shocks 1x1 atm. Then im doing sye and a driveshaft.
XJ93 03-18-2014 01:36 PM
Nice, post up some pics when you get her done.
The time now is 11:15 AM.
