need help no spark - JeepForum.com
post #1 of 4 Old 02-06-2014, 08:22 AM Thread Starter
baremetalcustom
need help no spark
I have a 93 yj with a 2.5l and ax5 trans with about 140,000 on it
I don't have spark can't get it to run, iv changed the computer, crank and cam sensor, distributor, ignition coil,
It turns over strong,
What's next to fix? Start tracing wires? Hints?
Plus I still need to bled the clutch since replaced some parts, so will haveing no pressure on the pedal cause this?
Need help!!!!!!!!!!![/SIZE]
baremetalcustom is offline
post #2 of 4 Old 02-06-2014, 08:36 AM
Mark05059
To answer the easiest question first. No the lack of clutch hydraulic pressure will have nothing to do with it not starting. When you turn the key to on does the Check engine light come on and then go off a bit later? Have you checked the fuses under the dash..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 4 Old 02-06-2014, 08:44 AM Thread Starter
baremetalcustom
No check engine light, the brake light turns on and off its only gauge light that goes on,
post #4 of 4 Old 02-06-2014, 11:05 AM
Que89YJ
Que89YJ is offline
