Need help on motor swap. - JeepForum.com
post #1 of 6 Old 06-16-2010, 02:49 PM Thread Starter
A4T1Rat
I have a 1989 Jeep YJ and I am putting in a 89 Cherokee 4.0 motor in it and I need a little help on the wiring side. I know that this motor is less popular but the price was right. so anyone out there help me out? what wires need to be spliced into the wrangler harness. Thanks
Injection is nice but Ide rather be Blown
A4T1Rat is offline
post #2 of 6 Old 06-21-2010, 01:24 PM Thread Starter
A4T1Rat
OK just a update... I found a 94 cherokee 4.0L motor and am getting ready to put it in . 4.2 is out and 4.0 is ready to go I know I will need to do something about the CPS maybe the hesco one. my only concern is the wiring as the harness was cut off at the firewall connector. I have searched and found a few posts about the wire conectors bur most list the terminal number. is ther anyone that has the color to color connections that need to be done? I looked at the motor swap tech posted here on the forum but a lot of the links are dead.
Thanks
A4T1Rat is offline
post #3 of 6 Old 06-21-2010, 01:59 PM
Bastidjeep
Piece of cake!I hope this helps! Top one is the 94 cherokee. The lower is your Wrangler.
Bastidjeep is offline
post #4 of 6 Old 06-23-2010, 01:30 PM Thread Starter
A4T1Rat
OK my wire colors are a little different, any body have the diagram from a 87 wrangler? or are they the same colors?
Thanks
A4T1Rat is offline
post #5 of 6 Old 04-21-2013, 12:33 PM
Que89YJ
H2 on the engine harness, G5 on the IP side. It depends on how you rewired it to make it work on where they are at.
http://www.jeepforum.com/forum/f12/9...dvice-1118478/
Que89YJ is offline
post #6 of 6 Old 04-21-2013, 12:40 PM
Que89YJ
Sorry posted to the wrong thread.
Que89YJ is offline
Motor swap, a 91, with an 88 motor, will a 94 fit? Joebio YJ Wrangler Technical Forum 12 05-15-2010 12:28 AM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
Motor Swap ? Yelladog1 TJ Wrangler Technical Forum 9 09-06-2009 10:39 PM
Motor swap? sor-fab TJ Wrangler Technical Forum 3 05-22-2006 08:28 PM
318 Motor Swap? bcshepard YJ Wrangler Technical Forum 7 10-11-2004 08:32 PM
