Need help Making my YJ go - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Need help Making my YJ go
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 09-08-2011, 02:18 PM   #1
TexasTrue
Background:
Bought a 91 YJ, 4.0L, 5 speed. This is my first jeep. I was rear-ended, so to make the most of my insurance money, I took the jeep apart myself and took just the tub and hood for paint and bodywork. In that time, I discovered the old wiring harness was toast. I replaced it with the E-Z 12 circuit wiring harness. That harness is not compatible with the computer in the front end. I am replacing the EFI with a Weber carburetor, removing the computer and going to a simple set-up.
Problems:
1. What distributor can I use that does not have the computer sensor plug? The ones I found are for the old CJ 4.2L engines. Will this work in my 4.0L YJ?
2. Do I need to replace the fuel pump as well?
I have read many of the threads on here debating carb/EFI, but I canít seem to find any that address this issue specifically. Any help on this issue will be greatly appreciated. There seem to be many strong emotions both ways on this issue. My mind is made up, the computer is gone, and now I need help making my poor jeep run again. Thanks.
TexasTrue is offline   Reply With Quote Quick reply to this message
Unread 09-08-2011, 03:26 PM   #2
oldtime_ironman
Basically it sounds like you're doing a "nutter" bypass. I imagine that any of the GM HEI kits are good for the distributor in this. I'm not an expert tho. Somebody who has done it on an 89 or earlier with the 4.2 would probably be able to help better.
oldtime_ironman is offline   Reply With Quote Quick reply to this message
carburetor , distributor , fuel injection , weber carb , wiring
