need help with lockers - JeepForum.com
post #1 of 19 Old 11-30-2011, 10:28 PM Thread Starter
BIGJoe29
if i have a stock 1990 yj, what r the specs for the gearing and such. i am looking at lockers but know nothing about this. any help will b appreciated
2.5L w/ AX-5, NP231J w/ Rugged Ridge SYE and XJ front driveshaft, open D30 and D35 w/ 4.10 ratio, stock JK 18in wheels w/ Spydertrax 1.25in spacers and 32in toyo at, 2.5in RC lift with .5in shackles(BESRK), rear TJ flares. 8.8 rebuild soon
BIGJoe29 is offline
post #2 of 19 Old 11-30-2011, 10:38 PM
95jeelyj
It's in the stickys.... But what motor and trans do you have ?
95jeelyj is offline
post #3 of 19 Old 11-30-2011, 10:42 PM
J33Pyj
I have a 90YJ with 4banger and 5speed. I run 4:88 gears and an Aussie in the front D30. Never an issue and the added traction is awsome.
90 yj/ 4:88 gears/33x12.50x15 Super Swamper TRXUS Mud Terrains/K&N air system/2.5L/D30front aussie equip'd/D35 rear / 3in BL/ 2in shackle lift / XRC8 Winch
If you havent broken it, you havent been wheelin
J33Pyj is offline
post #4 of 19 Old 11-30-2011, 11:23 PM
jeepinvader
You've got the 2.4L, so most likely your axles are 4.10 ratio. There's lots of threads and info on lockers, so searching will probably answer most of your questions.
Free Chuck!
jeepinvader is offline
post #5 of 19 Old 12-01-2011, 12:23 AM
plumber1
A lot on gearing depends on your tire size, final tire size not current size
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #6 of 19 Old 12-01-2011, 12:33 AM
dillonjm
2013 WK
First questions I'd ask is what are you looking to get out of your modifications, what mods do you currently have on the Jeep (IE lift, tire size, etc), are your axles currently stock or have they been swapped out for something stronger, etc, etc..
Answer all those and you should be able to get some good answers from the dudes on here.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #7 of 19 Old 12-01-2011, 12:43 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
This dude agrees! Figure out why you get stuck on the trail and go from there.
Luck Favours The Prepared
Anticanman is offline
post #8 of 19 Old 12-01-2011, 05:38 PM
burnout189
i would never lock the dana 35 rear. and i would never again buy a "lunchbox" style (lock-right, aussie...) locker for a street driven Jeep. go detroit, or a selectable style. :2cents:
this is going to be another one of those threads that turns into the OP talking about throwing 60's or 9's under the jeep
BARNHART'S AUTO REPAIR
burnout189 is offline
post #9 of 19 Old 12-02-2011, 12:17 AM Thread Starter
BIGJoe29
im just a rookie and know nothing haha. i am getting a 2.5 in lift and 31's shortly. do lockers keep the jeep in gear cuz i was doing some light offroad and i hit went over a curb sized bump and it popped out of gear. will lovkers solve this?
BIGJoe29 is offline
post #10 of 19 Old 12-02-2011, 12:21 AM
91BoD
No
Lockers keep the wheel with the most traction spinning and providing propulsion Vs. an open differential which will transfer power to the wheel with the least traction (IE if one tire is in the air you will go no where)
91BoD is offline
post #11 of 19 Old 12-02-2011, 08:26 AM
Spuznick242
Sounds like he has a loose bracket on the transmission or just happened to hit it just right that made it pop out of gear....its nothing that a locker will do.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #12 of 19 Old 12-02-2011, 08:41 AM
jeepster93
jeepster93's Avatar
If getting unstuck is the issue...
Get a winch.
A locker is just as likely to get you MORE stuck as to get you unstuck.
A locker will get you deeper into the stuck before you get...stuck, now deeper in the hole than without the locker. More stuck.
jeepster93 is offline
post #13 of 19 Old 12-02-2011, 10:22 AM
wendell
1987 YJ Wrangler
A locker won't hold up in the rear stock dana 35, you will waste your money. It's not if it will break, but when. You should upgrade to the ford 8.8 with a locker.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #14 of 19 Old 12-02-2011, 10:29 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm gonna go ahead and say it. OP: if you don't know what lockers are, you don't need them. Base your build on what you need on the trail. If you come back and say "I thought I had 4wd, why do the wrong wheels spin so much when I'm stuck?" then I would recommend a locker. In the meantime, put the catalog down and go for a drive.
post #15 of 19 Old 12-02-2011, 10:52 AM
burnout189
i just re-read my earlier post, and im sorry if i sounded like a jerk, i didnt mean to. lol
but i would agree, that you most likely dont need lockers yet. There is ALOT of reading for you to do on the interwebs, when you arent driving the jeep just click around here on jeepforum, or any other place for that matter.
Before you know it, you will be hip deep in the most interesting article you have ever read, and learning a ton about your jeep in the mean time.
differential , jeep , lockers , YJ
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
OX Lockers Tredloc TJ Wrangler Technical Forum 14 02-25-2009 05:07 PM
lockers deryk111 TJ Wrangler Technical Forum 13 02-10-2009 06:15 PM
Those with ARB lockers Brads_nky_yj YJ Wrangler Technical Forum 11 02-01-2009 01:10 AM
Lockers in front, lockers in back biffstephens TJ Wrangler Technical Forum 30 12-04-2004 02:45 PM
