need help on locker.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > need help on locker....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 09-21-2006, 07:33 PM   #1
bobbert350
i have a 88 yj with a open dana 35..i read about removing the pinion shaft im pretty sure its called that its between the spider gears..well i read that there is suposto be a bolt there i guess my car didnt get the memmo and there is no bolt at all not even a hole for one...how do i go about removing it now i dont want to just bash it out any help
bobbert350 is offline   Reply With Quote
Unread 09-21-2006, 07:35 PM   #2
bobbert350
i also check my haynes service manual that didnt help at all
Unread 09-21-2006, 07:37 PM   #3
angusbeef
There should be a pin that holds it in
angusbeef is offline   Reply With Quote
Unread 09-21-2006, 07:43 PM   #4
bobbert350
there looked like there was suposto be something like that on the side of the carrier but there was nothing there.. i kinda looked like there was suposto be a screw but it wasnt there
Unread 09-21-2006, 07:46 PM   #5
bobbert350
like is there anyone who did this that doesnt have that 12 1/4" bolt that could help me out like a write up
Unread 09-21-2006, 07:48 PM   #6
angusbeef
thats how mine was did you try a punch it took me a long time to figure it out but it will just push out with a punch
Unread 09-21-2006, 07:53 PM   #7
bobbert350
do i need to pull the axle out to put the lock right locker on..i mean like do i need to get a slide hammer to move the axle out a little bit
Unread 09-21-2006, 08:09 PM   #8
angusbeef
yes you need to pull the axles out a little to get the carrier out at least thats what i did I am not sure if you have to or not but its not that hard of a job its just very intimidating I would help you if you wern't too far away
Unread 09-21-2006, 08:18 PM   #9
bobbert350
thanks alot i just wanted to make sure i no how to install everything i just want to make sure im doing it right..i didnt do it at my house i did it a my buddies shop and i didnt no how to remove the pinion shaft since i didnt see that 12 pioint bolt i read about in like 10 different forums and didnt no what to do..so i decided just it was a good way to change the differential fluid and do it another day..but if u have anyother ideas or tips let me no
