Need Help, jeep stalls/loses power randomly.. - JeepForum.com
post #1 of 17 Old 07-16-2001, 07:45 PM Thread Starter
-D-
This just cropped up today as I was driving down the freeway!!! The previous owner said this kind of thing had happened to him and he fixed it a few times and I thought it might have been taken care of but....
The first incident today was at an intersection, idling at a red light, the light turned green, I pull ahead and almost about to shift into 2nd when the engine just loses power and dies. It turns over with the key and cranks to life immediatly. After that while just driving along in like 4th or 5th, I suddenly lose power and the rpms start falling, so I downshifted to third, it rev'ed up a little from the gears and then a moment later it fired back up with a little sputter out of the tail. It hasn't ever done since I got it (about 5 weeks and 2000 miles now, i had to commute a LOT this month). I don't really need to downshift to get it back to life, I didn't have to for a few of the instances, and the duration of the engine not "firing" varies between like half a second to 1 or 2 seconds. Does anyone know of what I can check out or look at?
I don't know if this is related but I also notice that if I am going down a hill and engine braking, I get a lot of sputtering out of the tail. It's a different sputtering than the firing back up from above but it's kind of like a popping sound. It also happens if I'm in neutral and I rev the engine up to over 3500 or so and then release the gas, while it's slowing down. Is this normal or is something really wrong with my rig? Thanks for all the help, this is a great board.
-D-
-D- is offline
post #2 of 17 Old 07-16-2001, 08:16 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Need more info - engine - year - FI? - Carb?
4 or 6?
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 17 Old 07-17-2001, 12:26 AM Thread Starter
-D-
ACK!!! Sorry, was about to insert that info, got caught up fixing some grammer and editing and completely for got to put that in. I have a '95 YJ Rio Grande, 2.5L I-4 Fuel Injected, completely stock as far as engine+drive train goes... 30x9.50 tires. Thanks.
-D-
-D- is offline
post #4 of 17 Old 07-17-2001, 08:25 AM
FLHT_FXRS_YJ
Sounds like something is going on in the fuel delivery system. Try some over the counter injector cleaners as a start. How many miles or on it?
post #5 of 17 Old 07-17-2001, 09:27 AM
jpwranglr9
Check if there has been any work on the exost. that popping when you rev and let go sounds like lack of back presher. i had the same problem when i took out my cat. its to to bad sence my muffeler is still a chamber style. i would go with what FLHT says to do. I also dont know if there is an idle adjustment or not on the TB. But if there is it may need to be adjusted a bit. if it is dieing when you let of on the gas and shift gears that could be it. That happened on a F150 we had. Good luck
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #6 of 17 Old 07-17-2001, 01:37 PM Thread Starter
-D-
Thanks for all the replies, I'll get some Injector cleaner tonite when I go get a fill-up. My YJ has about 72k miles on it. It's not dying when I shift gears, it's almost like it isn't firing or something, I just lose power and start to slow down quickly, sometimes I downshift, the wheels rev the engine and it fires up usually with a bit of a sputter. Happened once last night on my way home and once this morning on my way in actually. My fast-idle is around 1300 or so and my slow-idle is about 900.
-D- is offline
post #7 of 17 Old 07-17-2001, 03:45 PM
FLHT_FXRS_YJ
I had Cat back pressure problems on my 89 yj but it didn't act like what your describing. When the cat got plugged up I had no power and couldn't get any rpm's. It was a hell of a trip back from Lake Superior to southern Michigan. At Lake Superior starting to come home from a week of wheeling I could get a maximum of 2500 rpms. Buy the time I was about 50 miles from home all I could get was 1400 rpms. I towed her home at that point. If I'd have know it was just a plugged cat, I would have ripped it off with my bear hands rather than try to drive over 11 hours with such limited rpm's (normally a 6-7 hr trip) (towing a trailer with 4 wheelers, along with 3 people and a dog!).
Oh well, live and learn! Back to your problem, you might check all your vacuum hoses to make sure none are broken or disconnected. A broken one can really mess up how well an engine will run.
post #8 of 17 Old 07-17-2001, 03:46 PM
helter
Sounds like my old 4 cylinder Grand Am - I solved the probem by putting in 87 octane gas rather than 86 octane. It took like 3 visits to a garages before someone asked me what octane I was putting in. It stopped doing it after the first fill-up and never did it again. After living with it like that for months I felt really silly.
92 YJ - 30x9.5 BFG
helter is offline
post #9 of 17 Old 07-17-2001, 03:59 PM Thread Starter
-D-
Alright, I'll fill up with 87, drive it for a day then pour some injector cleaner and see what makes a difference. I'll also check vacuum lines when I get back to my parents place this weekend. Thanks for all the tips.
I have a stock muffler and it hasn't been subjected to any harsh abuse by my hand, just a little gravel banging it when I drove it on a supposed "easy trail" that turned out to be a gravel road. Should I get it checked out somewhere to solve the mystery of my engine braking - popping sound?
Thanks again for eveyrones help. Getting jeep grease on my hands is turning into a habbit or an addiction I'm not sure.. although I'd prefer it to be for mods rather than repairs.
-D-
-D- is offline
post #10 of 17 Old 07-19-2001, 12:31 PM
Moseley
Sounds liuke it might be your fuel pump. I had the same problem a couple of months ago and once I replaced the fuel pump and filter it disappeared. It's a real pain in the *** to replace because of the way it's installed in the factory but it does the tric
1993 YJ
4.0 high output, auto
3in Rough Country 32 in Kumho Venture MT
Banks Power full exhaust
KC daylighters on windshield
Warn 5x7 55w on the Warn front bumper
Warn rear bumper and tire carrier
Driver Fx race seats
raingler sport handles
diamond plated rear corners
rhino-lined interior
Red Jeep Club Member #40
Moseley is offline
post #11 of 17 Old 07-19-2001, 06:26 PM
bigjeep39
bigjeep39's Avatar
I am having similar problems, is there a miss somewhere when you step on the gas??
1998 TJ
Slow steady project.
bigjeep39 is offline
post #12 of 17 Old 07-20-2001, 09:54 AM
Tonka
2015 JK Wrangler
The popping is normal, especially when the o.e. cat and exhaust are old.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #13 of 17 Old 07-20-2001, 02:14 PM Thread Starter
-D-
I'm not getting a miss, or atleast I'm not noticing one. I do occasionally feel some drag or loss of power generally right after or right before a stall incident. I'm going to check out and maybe replace the cat and muffler first and if it still exists, I'll do the fuel filter and pump. Although that seems almost backwards so I might do the filter/pump first.
Is there any way to check out either of these two to see if they are faulty short of replacing them outright?
thanks everyone.
-D-
-D- is offline
post #14 of 17 Old 07-20-2001, 10:53 PM Thread Starter
-D-
Well nevermind, unless the exhaust is seriously clogged, I've eliminated that problem. My jeep just died on my way out of work today. Listening to the radio at an intersection about to hit the expressway and all of a sudden my car stalled, just died without any weird sounds or anything, and it won't start back up now. It'll crank but won't fire. Pushed it into a parking lot at work (luckily I wasn't far away) and went back inside to put a few more hours in. Dad's bringing a U-Haul car trailer by in a couple hours so I'll take it home to see what's up. I'll start with the fuel lines and the computer (previous owner had the computer fixed when this happened to him or so he said). Thanks for the help, now I really got to figure out what's wrong..
On the plus side, I got to use my new tow hooks and new tow strap AAA guy stopped and gave me a tow for about 50 yds to the parking lot entrance.
-D-
-D- is offline
post #15 of 17 Old 07-21-2001, 03:21 AM
Razskidoo
Had the same problem! Installed a new Kat back and muffler, fuel filter. Didnít solve the problem!
It comes and goes. I STILL havenít figured it out yet! (Iím installing a 350 small block when the 4.0 dies) Itís still kicking after 190,000 w/ this problem. But try this - You can check the fuel pressure w/ a fuel gauge to determined if the fuel regulator or fuel pump is bad (changing the pump is a pain). Hayens manual has a good description on the method to check fuel pressure! Check the cadilitic converter to see if itís burnd up too!
Reply with your findings
92 Wangler ,I-6 ,3"lift, 32x12.5
Razskidoo is offline
replaced fuel sending unit, now jeep stalls randomly Brenters YJ Wrangler Technical Forum 15 08-10-2007 10:55 AM
My 1993 Renegade 4L manual stalls randomly nsk11 YJ Wrangler Technical Forum 6 04-19-2007 10:51 AM
jeep loses power mtberbob YJ Wrangler Technical Forum 15 05-18-2006 06:51 PM
Jeep still randomly losing all power! BzJeep YJ Wrangler Technical Forum 7 05-31-2005 11:56 PM
Jeep loses power murphd TJ Wrangler Technical Forum 3 01-12-2005 08:22 PM
