Need help with High idle after mc2100 swap - JeepForum.com
post #1 of 12 Old 09-16-2013, 10:41 PM Thread Starter
c5wagner
I recently put a mc2100 with 1.08 venturi and size 48 jets in my 1989 jeep wrangler with the amc 258cid motor, but the thing will not idle below 1200 rpms. I checked all the vacuum lines and there are no leaks, the manifold to adapter and the adapter to carb all showed no signs of leaks with carb cleaner either. I plugged up the choke hole at the carb base and got a manual choke and that didn't change anything. My timing is set at 8*. Has anyone else had anything like this?
c5wagner is offline
post #2 of 12 Old 09-16-2013, 11:05 PM
booboowv77
How about your fast idle screw?
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #3 of 12 Old 09-16-2013, 11:07 PM Thread Starter
c5wagner
removed it trying to get the idle down, no effect
1989 Base YJ TBI 350, 4l60, Np231 SYE/6 pin planetary/Wide chain, D30 ARB, 8.8 ARB 4.56
c5wagner is offline
post #4 of 12 Old 09-16-2013, 11:30 PM
booboowv77
Does your throttle cable have slack in it or is it tight? Something is stopping it from going the whole way down.
Just my toy!
post #5 of 12 Old 09-16-2013, 11:36 PM
booboowv77
Also try backing off your fuel mixture, mine is only 3/4 of a turn out but I am running a 1.14 venturi.
Just my toy!
post #6 of 12 Old 09-16-2013, 11:38 PM Thread Starter
c5wagner
I've gone in and out with minor changes made. I think I'm going to try decreasing my jet size from 48 to 46
c5wagner is offline
post #7 of 12 Old 09-16-2013, 11:40 PM
booboowv77
I'm running 48's in mine and I get a nice normal 750 rpm and lower with no problems
Just my toy!
post #8 of 12 Old 09-16-2013, 11:45 PM Thread Starter
c5wagner
I have a feeling I have a terrible vacuum leak somewhere but I can't find it. I think it's vacuum because the plugs show lean conditions
c5wagner is offline
post #9 of 12 Old 09-16-2013, 11:47 PM
booboowv77
spray carb cleaner around the base and see if it changes anything. Alot of people problems at the gasket.
Just my toy!
post #10 of 12 Old 09-16-2013, 11:50 PM Thread Starter
c5wagner
I did that already, I checked all mounting surfaces to make sure they're not warped, replaced gaskets and no leaks still. This is the first thing I have been truly lost as what to do with my jeep
c5wagner is offline
post #11 of 12 Old 09-17-2013, 12:03 AM
booboowv77
I still think something is hold it up, I would double check that first. I have not had this problem but hopefully some one will chime in in the morning that might have other possible solutions.
Just my toy!
post #12 of 12 Old 09-17-2013, 01:04 AM Thread Starter
c5wagner
You were right, I very thoroughly checked all the throttle shaft parts and found a slight bend on the throttle connector causing a bind, it was very hard to see without VERY close inspection.
c5wagner is offline
