Need help with fuel tank removal? - JeepForum.com
post #1 of 5 Old 04-08-2009, 09:11 AM Thread Starter
nickstix
So recently I had a small problem and my fuel tank began leaking from a crack in it. I ordered a new fuel tank and its here at my house. I went outside today to start takeing off the old fuel tank and am alittle confused..
When im takeing the fuel tank off, do i unbolt the tank and drop it in order to get to the hoses that need to be disconnected? Or am i supposed to disconnect everything first and then un bolt it and drop it?
Because i was looking and i cant see how i will be able to get to the hoses with it still attached to the jeep...
I did a search and couldnt find any writeups on this, does anyone know of a writeup? or have any pictures to help me out?
nickstix is offline
post #2 of 5 Old 04-08-2009, 09:22 AM
mark12010
Where Ru in NY I am in Amsterdam, Approx. 30 mile west of Albany. I have dropped mine it is much easier with help. You need to place a Jack under the tank. Remove the 4 screws that hold the filler neck to the body. Lower the tank just low enough to get to the hoses on the top of the tank and the wires for the sending unit. If it is FI you will need to disconnect the wires for the in tank fuel pump as well. It is best to do while you are on "E" as the tank will weigh less. If you are close to me I would be more that happy to give you a hand.
mark12010 is offline
post #3 of 5 Old 04-08-2009, 09:26 AM
mjmangus
When I dropped mine I disconnected the fuel filler and vent line from the filler neck. I then lowered the tank and was able to disconnect everything else. You might want to label the fuel supply, return, and various vacuum lines cuz many of these may look alike. It's really not that difficult. Good luck.
mjmangus is offline
post #4 of 5 Old 04-08-2009, 09:50 AM Thread Starter
nickstix
Thanks for the advice, Im currently waiting for my friend to make his way over to my house to give me a hand. And the I already made sure the gas tank is empty.
Thanks for the offer Mark12010 but Im out on long island and thats a bit of a drive just to help with a gas tank.
nickstix is offline
post #5 of 5 Old 04-08-2009, 10:10 AM
mandng0
1979 CJ5
1. Placed 2 center blocks under the gas tank laying longways parallel to the frame.
2. I placed a 12x24 piece of wood on top of the jack and raised it up to the tank to use as support when lowering.
3. Remove filler neck too so you dont bend it or break it off
3. Unbolted the bolts as instructed leaving the 2 strap bolts for last.
4. After everything is unbolted, simply lower the jack and the tank will sit right on the blocks.
5. I slid the blocks right out from under the jeep and placed them on a dolly.
There are some extra details in my build thread.. good luck, its a PITA
mandng0 is offline
YJ Fuel Tank Removal Problem Matt53 YJ Wrangler Technical Forum 8 11-04-2009 08:22 AM
Fuel leaks from top of fuel tank on cool mornings.....why? jeepdrvr69 YJ Wrangler Technical Forum 4 06-29-2009 11:57 PM
Major vacume in fuel tank causing fuel to spill out bigredcherokee YJ Wrangler Technical Forum 2 09-28-2008 02:35 PM
87 YJ fuel tank and lines running to fuel pump 87yjjeep YJ Wrangler Technical Forum 2 05-27-2007 03:07 PM
Gas tank skid that requires no tank removal Thunderstrike TJ Wrangler Technical Forum 27 01-08-2006 11:41 PM
