need help with fuel economy - JeepForum.com
post #1 of 11 Old 07-31-2013, 06:57 AM Thread Starter
richtfan
90 yj 4.2 with the carter bbd carb.
5 sp manual tranny
tires are 30-950r15
i need to try to increase my gas mileage however I can.
The carb seems to run fine. I don't think there are any vacuum leaks.
it sounds as if it lopes a little, but that might be the exhaust.
any suggestions?
richtfan is offline
post #2 of 11 Old 07-31-2013, 08:21 AM
fourbtgait
1930 MK Patriot
5 sp manual tranny
tires are 30-950r15
any suggestions?
What is your gas mileage?
What is your axle ratios?
fourbtgait is offline
post #3 of 11 Old 07-31-2013, 08:49 AM Thread Starter
richtfan
i don't know the gear ratios other than to say that they are stock.
gas mileage the other day on the highway (hard top removed) was about 12-13 mpg.
richtfan is offline
post #4 of 11 Old 07-31-2013, 09:02 AM
jokerchief462
It's a little low. With the too removed you will see a small decrease in mpg.
A good tune up, tires at recommended psi and a good wheel alignment should be 15 mpg or more depends on how you drive also.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 11 Old 07-31-2013, 09:06 AM
Old4X
1990 CJ7
Tell us how your engine is tuned and what shape it is in:
Compression?
Vacuum reading at warm idle?
Timing chain slack in degrees?
Ignition timing?
Vacuum advance setting (number of turns out)?
OEM air filter?
Also, how do you drive:
RPM shift points?
Tire pressure?
Cargo load or empty?
Mostly short trips or long highway trips?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 11 Old 07-31-2013, 08:55 PM
jred
If I'm even moderately heavy on the gas pedal, my MPG drops from 17-18 down to 14. That's with the hard top on, and the 4.0L.
jred is offline
post #7 of 11 Old 07-31-2013, 09:00 PM
Rproject
1987 YJ Wrangler
You're a little low. A stock '87 with the 258 should have 3:07 gears in it. With a properly tuned carb, good plugs/wires/cap/rotor, a fresh oil change and clean air filter, you should be able eek out 16-17 mpg. Get a little heavy on the foot and that'll drop to 14 in a heartbeat.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 11 Old 08-01-2013, 07:15 AM
superj
i get 8-12 depending on how i drive. stock tires and suspension
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 11 Old 08-01-2013, 07:49 AM
vcallen7
Max tire pressure, clean air filter, high grade gas, general tune up, those are the easy things. You could also rebuild the carb
vcallen7 is offline
post #10 of 11 Old 08-01-2013, 08:48 AM
zeus87gn
1987 YJ Wrangler
Originally Posted by richtfan View Post
tires are 30-950r15
These are killing your fuel economy on the stock gears
You need 3.55's
Or you can remove your top, doors, back seat and spare tire to get a few more light poles down the road
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #11 of 11 Old 08-01-2013, 10:28 AM
fourbtgait
1930 MK Patriot
83 cj, 4.2, t5 tranny, bbd, no smog, 3.54 axles, 31x10.50 all terrain.
No top, 60mph on freeway and running around I get 14 mpg.
Best I've gotten is 16 mpg with full top, driving slower.
As others say, go thru your engine, tire size/gear ratio, drive slower.
