i have a 93 yj and when i bought it i didnt know much about them now i know a lil more and i see i payed to much and i dont have very much money to fix it and now im trying to make the best with what i got i would like to see if any one live around Milwaukee please help
what is it that you need to know, and help with... have you done a search on issues about rust here. there are a ton of threads relating to rust and the at home remedies done, either market or aftermarket.
i have looked it up and i have priced it out but the thing is it seems like the only way to fix it is to weld and i cant do that so i would need some one to do it for me and it is the classic rust on this jeep its at the rear shackle mount on both sides
ahhhh, yeah those are a serious pain in the canasta.. have you googled a body shop in your area. im sure if ya ask them, they might do it.
most repair shops carry torches and welding equiment for exhaust projects>
yea i have and some of the prices i think are a lil pricey a guy wants 500 per side not including materials so i was hoping that i can find some one on here that may live around here that could help or know of any other tricks that can make it last longer till i can get the money
hey i live near milwaukee...know a few guys with some welding skills but to tell you the truth, the rust will never be fixed...i suggest upgrading to a newer jeep like i did because my old YJ's frame cracked after just DD for a year after two rust "fixes"
i can help you out if you need it though... :cheers2:
My frame "cracked" there as well. Everyone I know was like WOW i have never seen that before. But I beefed up that area with a nice piece of 3/8" angle iron that has bolts that hold the skid plate at the same time..
it's not a public place but the guy does welding...for my jeep he welded up one whole side of the frame and put in a floorpan for 500 bucks...he would have to see what you want done. probably around 600ish from the problems you are describing.
also this guy is very good at what he does...he has been doing it for around 30 years and is the best out there and definitely a guy i would reccomend without any second thoughts.
Or just do a search for Phoenix wrecking yards and buy the back end of a damage jeep frame. Then have that welded on to your frame. Much less fabrications and that means cheaper. Avoid body shops you need a welding shop, much cheaper.
If you have a garage to work in you could do all the removing of parts and frame cutting. Then just get a mobile welder to come to your place to weld it. Then put it back together yourself. But, WI in winter, damn, not a good project this time of year.
yea its not that bad yet. i just want to get it before a shackle breaks loose but you are saying 600 for both sides and would that include the materials
You might be better off spending that $ by buying a mig welder and doing it yourself. It will take awhile to get up to speed, get some scrap and start playing. Find someone to bead or sandblast the area for you.
If the frame has more than just 1 or 2 areas that need minor repair, I wouldn't repair the frame without removing it first - it's a lot of "wrenching", but you'll end up with a much better job than you'd get by applying temporary "band-aids" with the frame in place. If you are unable to do the welding yourself (I wouldn't use frame-repairs as the place to learn how to weld), I would find a used frame in good shape, clean out the inside with a pressure washer, sand blast the outside & paint it with a good anti-rust paint, and then use a rust preventative oil (Ziebart & others have such a product that you can buy in quarts or gallons) on the inside - use this oil once per year on the frame as well as all the body cavities. You'll end up with a much better jeep in the end (for less cash too) than you will having someone weld a few patches over a "swiss cheese" frame.
Check Craigslist under auto services. With the economy so poor, their is a lot of skilled workers looking for extra work. You can either post looking for frame repair or call someone who has posted. You could probably find someone to work with you and you just pay them cash for their time worked.
I had bad rust at the rear shackles and repaired them only to later find more rust near the front by the steering box. And who knows what weak rust spots that I did not find. I suggest if your going to keep the rig a long time to get a rust free frame. I wasted alot of time and money trying to fix a frame that I ended up getting rid of. Find a good frame and don't look back.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
