Having done this before I recall a few points. PB blast the nuts on your U bolts. Chock front wheels, loosen lugs on offending side of axle, jack up that side and remove wheel, properly support frame with jack stands, Apply a large C clamp to your spring pack either in front of or behind your axle to stop the spring pack from separating. After you have removed the U bolts, jack up the axle to "unload" the springs and provide access to center pin "hole." Install the center pin and nut. Remove C clamp, lower axle and reinstall the U bolts. Put wheel back on, torque lugs, etc
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2
We will be going Metric every inch of the way.
Originally Posted by 40dog
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
