need help finding ratio for my D35 - JeepForum.com
post #1 of 7 Old 11-03-2009, 09:31 AM Thread Starter
parkerm26
First thing i did was took some advise and got all the numbers from my differential cover and tried to get the info i needed from the dana website. however no matter wat numbers i put in i got no results. could someone help me either identify or tell me where to identify and wat code to use?
I found on the tag on the bolts of the cover
52068008
3 07 5502-1
then on the cover itself
43225
061 3
REV-F
09 25 91 (i assume this is the date of production)
Thanks!
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
post #2 of 7 Old 11-03-2009, 09:40 AM
jbolty
jbolty's Avatar
3.07 is your number. the most hated of all jeep OEM ratios.
Sorry.
jbolty is offline
post #3 of 7 Old 11-03-2009, 09:41 AM
YJBlues
YJBlues's Avatar
looks like 3:07 to me, pretty standard for that year with a 4.0 and D35/D30
the 2.5's came with 4:11's, and I believe the few D44's that got put in came with the 4:11 ratio, though I wouldn't want to be quoted on that.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #4 of 7 Old 11-03-2009, 09:46 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
52068008
3 07 5502-1
43225
061 3
REV-F
Thanks!
I searched by year make & model and came up with BOM number 605528-1 on Dana's website, with 3.07 gears.
Dana Holding Corporation - The Expert Axle Bill of Material
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 7 Old 11-03-2009, 07:44 PM Thread Starter
parkerm26
hey thanks everyone. i saw that it coulda been 3.07 3.55 or 3.73 in the yj stock specs page. now im certain thanks again
post #6 of 7 Old 04-03-2010, 03:05 AM
schimmentix89
i have a 92 yj 6cyl would mine be 3.07 too
schimmentix89 is offline
post #7 of 7 Old 04-03-2010, 03:45 AM
Sleuthhound
could be 307, 355 or 373 as parkerm26 said. You'd have to check your diff tags, schimmentix89.
Sleuthhound is offline
Need help finding hub kit argirog TJ Wrangler Technical Forum 3 06-25-2009 02:13 PM
Finding Gear Ratio??? OutDoorDawg TJ Wrangler Technical Forum 5 12-21-2006 03:51 PM
Need help finding the right axle ratio! Fast29Car TJ Wrangler Technical Forum 3 12-17-2006 03:17 PM
Need help finding used ECM/ECU frprado YJ Wrangler Technical Forum 7 04-08-2005 07:12 PM
Finding Gear Ratio jeeperslax TJ Wrangler Technical Forum 3 07-09-2004 02:26 PM
