Need help with extended differential vent hoses - JeepForum.com
post #1 of 5 Old 07-14-2001, 06:00 PM Thread Starter
-D-
I heard that you shouldn't wade into water deeper than your hubs unless you extended your differential vent tubes. Since I have a mostly stock '95 YJ Rio Grande, I figured I'd probably want to extend them in case I ever decide to go swimming. After looking around my pumpkins I noticed that there was already a hose coming out from them. Since it's stock and I've never seen a differential vent host, I'm wondering if this is an already extended hose or something else.
Here are some pictures:
The hose comes out of the top right side of the front diff pumpkin and snakes around to near the radiator on the drivers side. It's the gray/white looking cap in the second picture (a little hard to recognize).
Is this standard for the '95 Rio Grande's or did the previous owner put them in? There is a similar one in the rear but I couldn't quite figure out where it went. Thanks.
-D-
-D- is offline
post #2 of 5 Old 07-14-2001, 11:18 PM
Tonka
2015 JK Wrangler
Those are factory diff vent hoses, and will do just fine on a stock rig.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 5 Old 07-15-2001, 01:59 AM Thread Starter
-D-
Cool. thanks for the help. Glad to know I won't drown my diffs when I go past a foot of water.
-D-
-D- is offline
post #4 of 5 Old 07-15-2001, 06:59 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
You can still suck water into your diff's .. very easy if you have leaky seals .. rule of thumb .. change the seals every two years for protection .. or whenever you see leaks happening (which ever comes first).
Change your diff fluid after every major dunking in the water (80 - 90 weight gear oil is recommended) to keep things clean. I just changed the diff fluids in my buddies axles yesterday .. they were dunked and the water in there was killer! The juice plopped out like chunky stew .. and there was some rusting already starting on the diff cover.
We cleaned the rust off using WD-40 and a wire brush attached to a drill.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 5 Old 07-15-2001, 08:36 PM
Tonka
2015 JK Wrangler
NaeKid followed up on what I didn't... Good catch!
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
Differential vent tube keeps leaking Whipper Snapper TJ Wrangler Technical Forum 15 01-02-2009 09:32 AM
front extended brake hoses 5.0YJ YJ Wrangler Technical Forum 6 10-30-2006 07:09 PM
Differential "vent" bakwoodj2 YJ Wrangler Technical Forum 1 09-06-2006 08:01 PM
Differential vent line.....? peanut YJ Wrangler Technical Forum 1 10-15-2005 10:33 AM
Extended Rear Drive Shaft vs Extended CV John Snyder YJ Wrangler Technical Forum 5 01-02-2003 07:51 PM
