need help dropping gas tank - Page 2 - JeepForum.com
post #16 of 19 Old 09-01-2011, 02:54 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Originally Posted by sptrmike View Post
man i spent the last two hours trying to drop this tank i feel like a monkey trying to pull a bannana peel over a water melon, i cant get the filler neck past the frame i tried dropping the pass side lower and the tank pushes the tail pipe against the spring and jams. i had way less grief regearing my axles,rebuilding the engine and trans. this might be an easy job with a 15 gal tank but theres just no room with a 20 it looks like im going to have to bolt every thing back up and start over removing the exhaust first this sucks
you can weld. cut it off and re-weld it when done
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #17 of 19 Old 09-01-2011, 02:58 PM
oldtime_ironman
Heh. Yeah I did the same thing. I took out the tailpipe totally and just put a short turn-out after the muffler, like only 4" long. Technically it counts as a tailpipe.
oldtime_ironman is offline
post #18 of 19 Old 09-01-2011, 03:12 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Its a jeep. you have to keep in mind the frame, tub, brackets, axle.... you can just cut off whatever is in your way.
Poke is offline
post #19 of 19 Old 09-01-2011, 05:16 PM Thread Starter
sptrmike
sptrmike's Avatar
i finally got it out, after removing the tail pipe it was a breeze, lots of room to put the new springs in after i por15 the frame. i notice a little rot where the body mounts go into the tub not to bad if i do it now . do i have to take out all the tub mount bolts to get it up high enough to weld in a new chanel i want to cut the rot right out and put new steel in
thanks mike
sptrmike is offline
'87 YJ fuel tank pressurized after dropping tank? Gooch YJ Wrangler Technical Forum 9 11-10-2010 06:19 PM
dropping YJ gas tank xcnick38 YJ Wrangler Technical Forum 6 01-18-2010 03:53 PM
Dropping My Gas Tank SOLOLUCKY YJ Wrangler Technical Forum 14 05-23-2008 10:58 AM
Dropping the gas tank scruffyjon YJ Wrangler Technical Forum 23 07-28-2006 10:58 PM
Dropping gas tank bowman YJ Wrangler Technical Forum 6 04-24-2006 11:33 AM
